I’m trying to acces outside to my HA. I did it with Home Assistant in a docker container, duck DNS, and nginx in docker. nginx generated SSL certificates, it works in local, but if I go with my phone or anything else on https://mydomain.duckdns.org, I have :
I searched on forums but most of them are in add-on, and some idears did’nt work.
In yaml I have :
http:
server_port: 8123
ssl_certificate: /opt/nginxproxymanager/letsencrypt/live/npm-25/fullchain.pem
ssl_key: /opt/nginxproxymanager/letsencrypt/live/npm-25/privkey.pem
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
use_x_forwarded_for: true
trusted_proxies:
- 172.21.0.2
ip_ban_enabled: false
login_attempts_threshold: 5
And gives me error :
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2023-08-26 18:53:58.292 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-26 18:53:58.501 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/opt/nginxproxymanager/letsencrypt/live/npm-25/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/opt/nginxproxymanager/letsencrypt/live/npm-25/privkey.pem'. (See /config/configuration.yaml, line 59). Please check the docs at https://www.home-assistant.io/integrations/http
2023-08-26 18:53:58.507 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2023-08-26 18:53:58.512 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2023-08-26 18:53:58.514 ERROR (MainThread) [homeassistant.setup] Setup failed for api: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.515 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2023-08-26 18:53:58.517 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.518 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2023-08-26 18:53:58.520 ERROR (MainThread) [homeassistant.setup] Setup failed for config: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.521 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of diagnostics. Setup failed for dependencies: http
2023-08-26 18:53:58.523 ERROR (MainThread) [homeassistant.setup] Setup failed for diagnostics: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.524 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of file_upload. Setup failed for dependencies: http
2023-08-26 18:53:58.526 ERROR (MainThread) [homeassistant.setup] Setup failed for file_upload: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.527 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of repairs. Setup failed for dependencies: http
2023-08-26 18:53:58.529 ERROR (MainThread) [homeassistant.setup] Setup failed for repairs: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.530 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2023-08-26 18:53:58.532 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.534 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of image_upload. Setup failed for dependencies: http
2023-08-26 18:53:58.535 ERROR (MainThread) [homeassistant.setup] Setup failed for image_upload: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:58.537 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of search. Setup failed for dependencies: websocket_api
2023-08-26 18:53:58.538 ERROR (MainThread) [homeassistant.setup] Setup failed for search: (DependencyError(...), 'Could not setup dependencies: websocket_api')
2023-08-26 18:53:58.540 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of analytics. Setup failed for dependencies: api, websocket_api
2023-08-26 18:53:58.541 ERROR (MainThread) [homeassistant.setup] Setup failed for analytics: (DependencyError(...), 'Could not setup dependencies: api, websocket_api')
2023-08-26 18:53:58.543 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image_upload
2023-08-26 18:53:58.544 ERROR (MainThread) [homeassistant.setup] Setup failed for person: (DependencyError(...), 'Could not setup dependencies: image_upload')
2023-08-26 18:53:58.546 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: analytics, auth, http, person
2023-08-26 18:53:58.547 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: (DependencyError(...), 'Could not setup dependencies: analytics, auth, http, person')
2023-08-26 18:53:58.549 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, auth, config, diagnostics, file_upload, http, onboarding, repairs, search, websocket_api
2023-08-26 18:53:58.550 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: (DependencyError(...), 'Could not setup dependencies: api, auth, config, diagnostics, file_upload, http, onboarding, repairs, search, websocket_api')
2023-08-26 18:53:59.800 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of network. Setup failed for dependencies: websocket_api
2023-08-26 18:53:59.803 ERROR (MainThread) [homeassistant.setup] Setup failed for network: (DependencyError(...), 'Could not setup dependencies: websocket_api')
2023-08-26 18:53:59.805 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2023-08-26 18:53:59.807 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:53:59.809 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of usb. Setup failed for dependencies: websocket_api
2023-08-26 18:53:59.810 ERROR (MainThread) [homeassistant.setup] Setup failed for usb: (DependencyError(...), 'Could not setup dependencies: websocket_api')
2023-08-26 18:53:59.930 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of zeroconf. Setup failed for dependencies: network, api
2023-08-26 18:53:59.932 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: (DependencyError(...), 'Could not setup dependencies: network, api')
2023-08-26 18:53:59.934 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http, webhook
2023-08-26 18:53:59.935 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: (DependencyError(...), 'Could not setup dependencies: http, webhook')
2023-08-26 18:53:59.937 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of bluetooth. Setup failed for dependencies: usb
2023-08-26 18:53:59.939 ERROR (MainThread) [homeassistant.setup] Setup failed for bluetooth: (DependencyError(...), 'Could not setup dependencies: usb')
2023-08-26 18:53:59.941 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ssdp. Setup failed for dependencies: network
2023-08-26 18:53:59.943 ERROR (MainThread) [homeassistant.setup] Setup failed for ssdp: (DependencyError(...), 'Could not setup dependencies: network')
2023-08-26 18:54:00.307 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2023-08-26 18:54:00.311 ERROR (MainThread) [homeassistant.setup] Setup failed for map: (DependencyError(...), 'Could not setup dependencies: frontend')
2023-08-26 18:54:00.313 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of alexa. Setup failed for dependencies: http
2023-08-26 18:54:00.315 ERROR (MainThread) [homeassistant.setup] Setup failed for alexa: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.317 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of upnp. Setup failed for dependencies: network, ssdp
2023-08-26 18:54:00.319 ERROR (MainThread) [homeassistant.setup] Setup failed for upnp: (DependencyError(...), 'Could not setup dependencies: network, ssdp')
2023-08-26 18:54:00.323 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend, http
2023-08-26 18:54:00.325 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: (DependencyError(...), 'Could not setup dependencies: frontend, http')
2023-08-26 18:54:00.328 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mqtt. Setup failed for dependencies: file_upload, http
2023-08-26 18:54:00.331 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: (DependencyError(...), 'Could not setup dependencies: file_upload, http')
2023-08-26 18:54:00.333 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of thread. Setup failed for dependencies: zeroconf
2023-08-26 18:54:00.335 ERROR (MainThread) [homeassistant.setup] Setup failed for thread: (DependencyError(...), 'Could not setup dependencies: zeroconf')
2023-08-26 18:54:00.337 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of stream. Setup failed for dependencies: http
2023-08-26 18:54:00.339 ERROR (MainThread) [homeassistant.setup] Setup failed for stream: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.343 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of my. Setup failed for dependencies: frontend
2023-08-26 18:54:00.346 ERROR (MainThread) [homeassistant.setup] Setup failed for my: (DependencyError(...), 'Could not setup dependencies: frontend')
2023-08-26 18:54:00.349 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of conversation. Setup failed for dependencies: http
2023-08-26 18:54:00.350 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.352 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of apple_tv. Setup failed for dependencies: zeroconf
2023-08-26 18:54:00.355 ERROR (MainThread) [homeassistant.setup] Setup failed for apple_tv: (DependencyError(...), 'Could not setup dependencies: zeroconf')
2023-08-26 18:54:00.357 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_source. Setup failed for dependencies: http
2023-08-26 18:54:00.359 ERROR (MainThread) [homeassistant.setup] Setup failed for media_source: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.363 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of panel_iframe. Setup failed for dependencies: frontend
2023-08-26 18:54:00.365 ERROR (MainThread) [homeassistant.setup] Setup failed for panel_iframe: (DependencyError(...), 'Could not setup dependencies: frontend')
2023-08-26 18:54:00.368 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of application_credentials. Setup failed for dependencies: auth, websocket_api
2023-08-26 18:54:00.370 ERROR (MainThread) [homeassistant.setup] Setup failed for application_credentials: (DependencyError(...), 'Could not setup dependencies: auth, websocket_api')
2023-08-26 18:54:00.372 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_health. Setup failed for dependencies: http
2023-08-26 18:54:00.374 ERROR (MainThread) [homeassistant.setup] Setup failed for system_health: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.376 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of hacs. Setup failed for dependencies: http, websocket_api, frontend, repairs
2023-08-26 18:54:00.378 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration hacs: (DependencyError(...), 'Could not setup dependencies: http, websocket_api, frontend, repairs')
2023-08-26 18:54:00.380 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: http
2023-08-26 18:54:00.382 ERROR (MainThread) [homeassistant.setup] Setup failed for history: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.384 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tts. Setup failed for dependencies: http
2023-08-26 18:54:00.385 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.387 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of stt. Setup failed for dependencies: http
2023-08-26 18:54:00.389 ERROR (MainThread) [homeassistant.setup] Setup failed for stt: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:00.689 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of energy. Setup failed for dependencies: websocket_api, history
2023-08-26 18:54:00.690 ERROR (MainThread) [homeassistant.setup] Setup failed for energy: (DependencyError(...), 'Could not setup dependencies: websocket_api, history')
2023-08-26 18:54:00.692 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of assist_pipeline. Setup failed for dependencies: conversation, stt, tts
2023-08-26 18:54:00.694 ERROR (MainThread) [homeassistant.setup] Setup failed for assist_pipeline: (DependencyError(...), 'Could not setup dependencies: conversation, stt, tts')
2023-08-26 18:54:00.701 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of sonos. Setup failed for dependencies: ssdp
2023-08-26 18:54:00.710 ERROR (MainThread) [homeassistant.setup] Setup failed for sonos: (DependencyError(...), 'Could not setup dependencies: ssdp')
2023-08-26 18:54:00.725 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: http, webhook, person, websocket_api
2023-08-26 18:54:00.728 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: (DependencyError(...), 'Could not setup dependencies: http, webhook, person, websocket_api')
2023-08-26 18:54:00.816 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of homekit. Setup failed for dependencies: http, network
2023-08-26 18:54:00.830 ERROR (MainThread) [homeassistant.setup] Setup failed for homekit: (DependencyError(...), 'Could not setup dependencies: http, network')
2023-08-26 18:54:02.961 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of camera. Setup failed for dependencies: http
2023-08-26 18:54:02.964 ERROR (MainThread) [homeassistant.setup] Setup failed for camera: (DependencyError(...), 'Could not setup dependencies: http')
2023-08-26 18:54:02.994 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: application_credentials, assist_pipeline, bluetooth, cloud, conversation, energy, frontend, history, logbook, map, media_source, mobile_app, my, network, person, ssdp, stream, system_health, usb, webhook, zeroconf
2023-08-26 18:54:02.996 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: application_credentials, assist_pipeline, bluetooth, cloud, conversation, energy, frontend, history, logbook, map, media_source, mobile_app, my, network, person, ssdp, stream, system_health, usb, webhook, zeroconf')
I don’t know why he doesnt know the path, and don’t know how to know the good path to avoid this error… With this, even in local it doesnt work.
And if I put only in yaml, local works but no outside with https://mydomain.duckdns.org
http:
server_port: 8123
trusted_proxies:
- 172.21.0.2
