- I am unable to access my HA remotely. The connection times out (not refused, but timing out).
- I am running Home Assistant OS with Supervisor on a Ubuntu VM.
- I have port forwarding set up for external connections to another port (not default 8123).
- I am using DuckDNS with built in Let’s Encrypt, so no HTTP access, only HTTPS
- The SSL certificate is fine and valid.
- I can connect internally via my IP on port 8123, but I cannot connect externally.
- Port forwarding is working to the VM. To confirm this, I set up the SSH add-on and was able to access ssh externally just fine! It’s just main HA access not working.
- A while ago I had the same issue, and updating Home Assistant to the latest version made everything work fine for a while. I am running the latest HA version and OS.
- I cannot see any issues in any logs.
- I’d rather not complicate the scenario with a reverse proxy as everything worked for a long time. Nothing has changed AFAIK.
- I don’t have IP banning enabled or anything like that in my HTTP section of the config.
Help is appreciated.
EDIT:
I edited the config to remove the HTTPS settings.
No difference externally on HTTP vs HTTPS - still cannot access HA, so I switched it back to HTTPS
