Hi community I need your help…
So duckdns solution in order to be ale to get connected from out side works good.
I’ve also configure it via the app to directly use the https://blavla.duckdns.org
So what is the problem :/, so when I try to log in via the local as follows https://192.168.1.117:8123 I get the correct page That requesting me to put user name and password
But than after giving the password I get the following
I don’t know what is done wrong here.
I’ve heard some solution with dnsmask but I don’t like the idea that my router will use some dns redirect that will be done from my VM… Since if it will be under load my other computers that using the router may get hit…
Please advise
Asaf
