Unable to connect to Home Assistant. x86 Firefox
Hi
I have a problems with HA connection after OS installation
the weirdest thing that this problem is in firefox browser only…
browser restart can help for a short time… but after several page refreshes it uprear again
other browsers from this IP works great
Hello, I have the same problem. No connection is possible with Firefox (current version). Even from different PCs. With Chrome, Edge or Safari, access works without problems.
Does it seem to be the browser?
I’m having the exact same problem. Chrome, mobile, android app all works, but Firefox does not.
I’m running Firefox 110.0 on Fedora.
Another “same here”. It works fine with Chrome and Safari, just not Firefox.
I’ve tried “Forget about this site” and browser restarts. I’ve also emptied my dashboard because I’ve seen reports that “external” cards can create issues. No luck.
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:80
Integration: HTTP (documentation, issues)
First occurred: 9:42:36 AM (13 occurrences)
Last logged: 10:01:59 AM
Login attempt or request with invalid authentication from XXX (XXX). Requested URL: '/auth/token'. (Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:109.0) Gecko/20100101 Firefox/110.0)
It has worked before, just not after the latest updates I feel. I am using the Duck DNS addon with Let’s Encrypt configured.
Edit: A third “Forget about this site” plus browser restart helped somehow.
You’ll need to reset your Firefox to Default settings:
  • On Windows you can do this by clicking the three horizontal dash marks in the upper right corner (underneath the “Close” button).
  • Click “Help”
  • Click “More Troubleshooting…”
  • Click “Refresh Firefox” underneath ‘Give Firefox a tune up’
Let Firefox cycle, reopen Firefox and log into your local instance of Home Assistant. Done
Reseting to defaults does not helped me.
main bug is using dns-over-https. complete turn-of this feature and recheck. It is helped for me.
I think this approach will help you when your try to connect within local network using dns name (not ip).
but in my case this manupulation helped also for direct connectiton by ip. I don’t understand why.
Anybody work this out? I have tried all of these and more
In my case the reply above yours fixed my issue. I didn’t realize firefox defaulted to not using my router’s DNS, which uses the exact same DNS over HTTPS/SSL, but my dns server has DNS overrides for my external domain name to set the IP to the local ip rather than my external one, reversing hairpins and keeping it on the same local switch.
Turn off DNS over HTTPS! and move that functionality to your home router
Can confirm that this worked for me. Went into Firefox settings and added my internal DNS name for my home assistant to the DNS over HTTPS exclusion list and it started working right away.
Thanks!
