Hi everyone, I’m having trouble setting up my yellow for the first time. Upon receiving power, the red LED goes on and the yellow LED flashes for ~10 seconds before turning solid. Using the serial monitor, I can see it’s stuck at these lines, presumably because it can’t connect to the internet:
Welcome to Buildroot
yellow-installer login: [ 15.711325] haos-flash[229]: Getting latest Home Assistant OS version from channel stable...
[ 15.749090] haos-flash[232]: curl: (6) Could not resolve host: version.home-assistant.io
[ 17.492738] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 36.032783] cam-dummy-reg: disabling
I have it connected to a Eero router and the weird thing is I can see it in the app as “yellow-installer”, but going to that IP address or http://homeassistant:8123 times out, as does running ping
. Anyone have guesses on what I could try next? One note, I bought the PoE kit but am using a 12v barrel plug for power
