Hi, I’m trying to use mqtt to let home assistant know the status of my computer, but i can’t seem to connect to the mqtt server outside of the machine the ha is run on. I tried using mqtt explorer to connect but it wont. Here are the logs of the mosquito broker addon:
s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting cont-init: info: running /etc/cont-init.d/mosquitto.sh [11:23:37] INFO: Certificates found: SSL is available cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0 cont-init: info: running /etc/cont-init.d/nginx.sh cont-init: info: /etc/cont-init.d/nginx.sh exited 0 s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun mosquitto (no readiness notification) services-up: info: copying legacy longrun nginx (no readiness notification) s6-rc: info: service legacy-services successfully started [11:23:39] INFO: Starting NGINX for authentication handling... [11:23:39] INFO: Starting mosquitto MQTT broker... 2022-10-02 11:23:39: Warning: Mosquitto should not be run as root/administrator. [11:23:41] INFO: Successfully send discovery information to Home Assistant. [11:23:41] INFO: Successfully send service information to the Supervisor.
What error are you getting from the connecting machine.
Disconnected from server
