I got a problem lately - would like to say it has something to do with the last update to 0.118.3 release but I don’t think that’s the case (I even went back to the previous release 0.118.2 using a snapshot). Here below is my current log summary, to me it looks like I got a corrupt database. Question is, how do I fix that? Or is that not the root cause of my current trouble when connecting to nabu-casa? Sorry about the german log messages but all you need to know is:
Die Nachricht ist zum ersten Mal um 15:52:03 aufgetreten und erscheint 3364 mal.
The message first occured at 15:52:03 and showed up 3364 times.
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-11-24 16:15:33.236427', '2020-11-24 16:15:33.236427', 'cbe01b0aff47fe2d26895d05d87ef9d6', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
17:15:39 – Recorder (ERROR) - Die Nachricht ist zum ersten Mal um 15:52:03 aufgetreten und erscheint 3364 mal
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2020-11-24 16:15:33.236427', '2020-11-24 16:15:33.236427', 'cbe01b0aff47fe2d26895d05d87ef9d6', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
Connection problem to snitun server
17:15:38 – /usr/local/lib/python3.8/site-packages/hass_nabucasa/remote.py (ERROR) - Die Nachricht ist zum ersten Mal um 15:51:54 aufgetreten und erscheint 398 mal
Can't connect to SniTun server eu-west-2.ui.nabu.casa:443
17:15:38 – /usr/local/lib/python3.8/site-packages/snitun/client/client_peer.py (ERROR) - Die Nachricht ist zum ersten Mal um 15:51:54 aufgetreten und erscheint 398 mal
Unable to activate Alexa Report State: Cannot connect to host alexa-api.nabucasa.com:443 ssl:default [Try again]. Retrying in 30 seconds
17:15:13 – Home Assistant Cloud (WARNING) - Die Nachricht ist zum ersten Mal um 15:52:18 aufgetreten und erscheint 143 mal
Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
17:11:28 – /usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py (WARNING) - Die Nachricht ist zum ersten Mal um 15:51:48 aufgetreten und erscheint 70 mal
Platform error sensor.yr - Integration 'yr' not found.
17:11:00 – Hass.io (ERROR) - Die Nachricht ist zum ersten Mal um 16:01:16 aufgetreten und erscheint 2 mal
