Unable to connect to the front end (Solved: Migrated to Remote UI)
Today my home-assistant_v2 database file got stuck in a loop.
Increased with 100mb every couple of seconds and HASS became very slow.
I replaced this file with a backup from 2 weeks ago.
Restarted HASS and now I cant connect to my front end.
The log dont say anything usefull.
Anyone got a clue how I can get the front end up and running again?
Just delete the dB and restart. Has will create a new one
Yes it did create a new one, but no front end.
Unable to connect to Home Assistant or
This site can’t be reached
The webpage at https://**.duckdns.org/lovelace might be temporarily down or it may have moved permanently to a new web address.
can you ssh in and do a restart?
Unplugged the power of the PI to do a restart.
Is that sufficiënt?
Did that 3 times and still no front end, can acces the config folder etc
Are there any errors in the homeassistant.log file in the config folder?
Most of them are warnings and some waze travel time errors.
Will comment some components, like waze and do another restart.
2019-04-04 23:10:41 WARNING (MainThread) [homeassistant.components.http]    legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
    2019-04-04 23:10:47 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=2 from 2019-04-04 20:16:27.968036)
    2019-04-04 23:10:49 WARNING (MainThread) [homeassistant.loader] You are using a custom component for light.proxy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
    2019-04-04 23:10:49 WARNING (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change light/proxy.py to proxy/light.py. This will stop working soon.
    2019-04-04 23:10:51 WARNING (MainThread) [homeassistant.components.sensor.darksky] The 'update_interval' option (with value '0:05:00') is deprecated, please replace it with 'scan_interval'. This option will become invalid in version 0.91.0
    2019-04-04 23:11:00 WARNING (MainThread) [homeassistant.components.sensor.template] Template sensor br_day_forecaste1 has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
    2019-04-04 23:11:00 WARNING (MainThread) [homeassistant.components.sensor.template] Template sensor br_day_forecaste2 has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
    2019-04-04 23:11:00 WARNING (MainThread) [homeassistant.components.sensor.template] Template sensor br_day_forecaste3 has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
    2019-04-04 23:11:03 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
    2019-04-04 23:11:03 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
RROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1056)
2019-04-04 23:19:30 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: WRONG_VERSION_NUMBER
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
Maybe something to do with this?
likely…
not that i know how to fix that.
Do you have any more recent backups that you can restore from?
Yes, tried 2 backups but front end doenst pop up on both of them?
Something to do with my router and blocked something?
Found out this topic: Connectivity Issues - duckdns
Apparently it has something to do with DuckDNS and my internal network.
I found out that I can acces my frontend on4G.
Does your router support NAT loopback (hairpinning)?
Dont know but it was working from feb 2018 untill yesterday.
All of a sudden it s.topped and only working on 4G
Ah ok. Unlikely to be the router then.
Did your ISP turn on CGNAT?
It was working when i left for work, when i came back front end wasnt available anymore.
I will try restart my router and see if that fixes the issue
I just gave up :slight_smile:
Updated HASS to 0.91 through 4G and activated remote UI.
Thanks all for helping
What is that “RemoteUI” thing?
I have similar to your problem. LovelaceUI stops working and I have to login to ssh to restart HA in order to connect again, so i’m wondering if this RemoteUI will help me too …
Its the Remote UI service from Nabu Casa
https://www.nabucasa.com/config/remote/
