Hello everyone.
I wanetd to migrate Home Assistant from QEMU Virtual Machine to Raspberry Pi so i installed Raspbian (Buster) on RPi3 and installed Home Assistant supervisor. Installation process is same as was on qemu vm.
curl -sL "https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh" | bash -s
Then i created a snapshot on QEMU installation and moved that backup file to raspberry pi (/usr/share/hassio/backup) and reverted snapshot. One issue (so far) persisted after that, and that is the log file is filled with error messages like this bellow. on raspberry pi.
2020-05-03 21:35:01 ERROR (Thread-2) [homeassistant.components.mqtt] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2020-05-03 21:35:01 WARNING (Thread-2) [homeassistant.components.mqtt] Disconnected from MQTT (5).
As far as MQTT configuration concerned i only have two binary sensors (mqtt platform) . HA is not supposed to connect to any MQTT broker, so i don’t understand why these messages appear.
Bellow is binary sensor configuration where mqtt is configured.
binary_sensor:
sensors:
garage_door:
friendly_name: Garazna Vrata
device_class: door
value_template: "{{ is_state('input_boolean.garage_door','on') }}"
- platform: mqtt
state_topic: "zoneminder/1"
device_class: motion
qos: 0
value_template: >-
{% set object = namespace(found="OFF") %}
{% for x in value_json["detection"] -%}
{% if x.label == "person" or x.label == "car" %}
{% set object.found="ON" %}
{%- endif %}
{%- endfor %}
{{object.found}}
- platform: mqtt
state_topic: "zoneminder/2"
qos: 0
value_template: >-
{%- endif %}
{%- endfor %}
{{object.found}}
HA version is 0.109.3.
Can anyone help on what is happening here? Where is it trying to connect and why. How to get rid of these messages?
EDIT:
I should probably add that I’m using Mosquitto broker addon. If i disable Mosquitto, these messages do not appear.
This is Mosquito configuration:
logins:
- username: zm-mqtt
password: somepassword
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
