Hello!
I am struggling to install ESPHOME onto a NodeMCU esp32.
Originally I believed the error to be coming from my wifi password, as it contained special characters which may have caused issues with the string parsing, so I changed that, but am still getting stuck in the same place. It compiles and then the following error happens after it tries to connect to wifi:
Serial output error:
[14:10:52]Guru Meditation Error: Core panic'ed (Interrupt wdt timeout on CPU1)
[14:10:52]Core 1 register dump:
[14:10:52]PC 0x4000c71 PS 0x00060034 A0 0x8008af A1 0x3fbc0
[14:10:52]A2 0x3fb058 A3 0x3f17778 A4 0x00000014 A5 0x3fbe0
[14:10:52]A6 0x3fbe8 A7 0x00000001 A8 0x00000001 A9 0x3f17779
[14:10:52]A10 0x000000a A11 0x3fb060 A12 0x8008bb A13 0x3fbe0
[14:10:52]A14 0x00000008 A15 0x00000001 SAR 0x00000012 EXCCAUSE 0x00000006
[14:10:52]EXCVADDR 0x00000000 LBEG 0x4000ce LEND 0x4000cf LCOUNT 0xffff
[14:10:52]
[14:10:52]ELF file SHA256: 000000000000000
[14:10:52]
[14:10:52]Backtrace:0x4000c71:0x3fbc00x4008af:0x3fbc00x4008ca:0x3fbc00x4008c5a0x4008455e
[14:10:52]
[14:10:52]ore 0 register dump:
[14:10:52]PC 0x40086f2 PS 0x00060634 A0 0x80116fe A1 0x3fb080
[14:10:52]A2 0x00000001 A3 0x00000004 A4 0x3fce8 A5 0x00000040
[14:10:52]A6 0x00000000 A7 0x3fb204 A8 0x80083fb A9 0x3fb070
[14:10:52]A10 0x00000000 A11 0x3fb174 A12 0x00000001 A13 0x00000001
[14:10:52]A14 0x00060620 A15 0x00000000 SAR 0x0000001e EXCCAUSE 0x00000006
[14:10:52]
[14:10:52]
[14:10:52]Backtrace:0x40086f2:0x3fb0800x40116fb0x3fb0b 0x40089c2:0x3fb0e
[14:10:52]
[14:10:52]Rebooting...
Here is my configuration:
esphome:
platform: ESP32
board: nodemcu-32s
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "55f5a9ce7b2f6e4ca8101f75d5b0764f"
wifi:
ssid: "my-ssid"
password: "my-password"
ap:
ssid: "Esp32 Fallback Hotspot"
password: "XRNBsJcM6wzA"
captive_portal:
NodeMCU ESP-32S V1.1
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
ESPHome v2021.11.4
Home Assistant 2021.11.5
pi400
I’m new to ESP32 and home-assistant, and debugging these errors. I’m unfarmiliar with how to parse these logs, I am interested in learning how/using a tool to do it.
Can anyone help provide me with a direction on what I should try next next? A link to a debugger script/tool would be useful too.
Thank you
Edit:
Things I’ve tried without success:
Swapped boards (I have a spare of the same board)
Erasing flash memory via esptool.py github download and running erase_flash on dev/ttyUSB0. I’m not sure that it has worked as I get this:
[16:38:35][C][ota:452]: There have been 5 suspected unsuccessful boot attempts.
