Tried reinstalling HA, and installing on a different microsd.
Could not connect.
I have a Plusnet Hub 2 router (a UK ISP), is this something to do with router settings? I’m lost as to what to do next. TIA
ETA: Further googling suggests something about mDNS? Could this be a router setting that I need to change?
ETA: I’ve purchased new microSD cards, working on the assumption that both cards I used are corrupt/not good enough. Doesn’t feel like the issue but it’s all I got
I will try again with the new microSD cards, in the meantime thanks to all who responded, looking forward to more ideas in the morning! Goodnight.
Im certain. I connected a screen to the RPi, and hovering over the network icon top left shows the ethernet IP which is x.x.x.124 and the wlan IP which is x.x.x.126
Your browser is not trying to connect through httpS instead of http?
What does your browser return?
Are you using browser add-ons?
Did you try with a private session?
If you are sure about the IP address, you should keep trying with that.
Firefox: can’t establish a connection to the server at 192.168.1.124:8123
Edge: 192.168.1.124 refused to connect
Chrome: 192.168.1.124 refused to connect
