My spotify integration stopped working a week ago, and I have been reading and trying every tip and instruction on the net.
I have made several apps on developer.spotify, with all the redirect uri I can think of, both, local IP, Duckdns (running with Let’s encrypt) and even the nabucase url.
Trying to connect throght the spotify app, it throws all kinds of erreors: not found, 404-errors and sometime the redirect window closes and the integration just states ‘ERROR’.
Both the two apps in spotify is registrerd with client_id and client_secret under Application cridentials
Using the Nabucasa option seems to work (at first). I get a sucessfull integration message. But returning to the Settings/integration, the Spotifiy integration shows an error: Retrying setup: http status: 429, code:-1 - /v1/me/: Max Retries, reason: too many 429 error responses
Then it actually comes to life now and then. I get the Spotify card in Lovecale with playlist, but it usually lasts for some minutes and then is gone. Som minutes later, it sometimes reapear.
In the log I now get this error:
Logger: aiohttp.server
Source: helpers/config_entry_oauth2_flow.py:205
First occurred: 16:21:47 (5 occurrences)
Last logged: 16:35:06
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 220, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 196, in get
return await super().get(request, flow_id)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 95, in get
result = await self._flow_mgr.async_configure(flow_id)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 260, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 335, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 300, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(self.external_data)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 169, in async_resolve_external_data
return await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 205, in _token_request
resp.raise_for_status()
File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1004, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url=URL('https://accounts.spotify.com/api/token')
Please HELP!!
