Im new on home assistant and manage to go through all the main configurations on HA but Im stuck with the xiaomi gateway, sometimes it works and gets recognized and after I did my first automations it stopped being recognized along with all the sensor I have connected to it, tried all the troubleshooting described on the xiaomi_aqara component page with no luck, firmware version of the gateway 1.4.1_167.0158
I tried with MAC and without the MAC, I have tried a lot of suggestions of similar conversations on this forum, dont no what else to do, below you can see the logs I get (doesnt say much), by the way Im running HASSIO on a Raspberri Pi 3
Despite it say Im not puting the key you can see as per my conf file that the key is there
Setup failed for xiaomi_aqara: Component failed to initialize.
22:50 setup.py (ERROR)
No gateway discovered
22:50 components/xiaomi_aqara/init.py (ERROR)
Setup of xiaomi_aqara is taking over 10 seconds.
Key is not provided for gateway None. Controlling the gateway will not be possible
22:49 components/xiaomi_aqara/init.py (WARNING) - message first occured at 22:49 and shows up 2 times
Hi Jrwolf
Yes, I have it enabled, I have also restarted this function and refreshing the password multiple times and updating on campus the configuration
File , still no luck =(
I just updated also to the latest hassio version and xiaomi gateway firmwire and my gateway also stopped working. Got al kinds of different errors. After Some trial and error in the config.yaml i came to the conclusion the problem wasn’t with hassio but with the gateway or my router.
First i pulled the gateway out, put it back, Waited till the flashing blue light stopped and restarted hassio. Then i restarted my router and after is was fully back online i restarted hassio agian. And after this it started to work again.
Checked my config and i saw i deleted the mac and host today to get it working agian. So i have only the key In my config. Also all letters of the key are in capital. Also the ip adres at host was between “qoutation Marks”
The curious thing is that it stopped working as soon as I started to set up automations with a couple of motion sensors that I have setup on the gateway.
By the way still havent figured out how to downgrade the firmware but as per what I have searched Im not sure if it is possible.
Guess what, it’s working again now out of nothing. Same configuration, I was first thinking a firmware update from Xiaomi to the gateway, but as soon as I added some automations the issue reappeared
