When I added my kitchen lights into HA somehow I was still able to control them using the Ikea remote control as well as using HA. However after having updated the remotes firmware, I can only either pair lights so they work in HA or the remote but not both
Does anyone know what I’m doing wrong?
After pairing the device to HA I tried the following to pair with the remote, but it then stops its working in HA…
Keep the remote within 5cm (2 inches) of the light source and press the pairing button for 10 seconds (located under the remote control lid).
A red light will shine on the remote control and, when it’s successfully paired, the light source will dim and flash once.
TRADFRI remote control (E1524/E1810) by IKEA
2 x TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)
zigbee2mqtt & Mosquitto broker & CC2531
Zigbee has support for binding which makes it possible that devices can directly control each other without the intervention of zigbee2mqtt or any home automation software.
A use case for this is e.g. the TRADFRI wireless dimmer. Binding the dimmer directly to a bulb or group has the following advantages:
Smoothness; this will greatly improve the dimming feedback as the dimmer directly dims the bulb and thus does not have to make the MQTT/home automation software roundtrip.
It will work even when home automation software, zigbee2mqtt or the coordinator is down.
Speaking of firmware updates for the CC2531. I have the CC2531+antenna that came preflash with the latest firmware as of today. How often does the CC2531 gets a firmware update? Is it critical to have it update to latest when there is one? I do not have the components to update myself is why I am asking.
