Unable to control switches anymore
Everything was working fine. Then one morning, my automation stopped working. I am now not even able to toggle my switches from HA dashboard.
My Setup:
HA running on a VM through Oracle Virtual Box
SONOFF Zigbee 3.0 dongle-E used as gateway
Add-Ons involved: Zigbee2MQTT, Mosquitto broker
Zigbee2MQTT (V 1.39.1-1) Configuration:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://core-mosquitto:1883
  user: mqttuser
  password: Pakistan123
serial:
  port: >-
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240220093323-if00
  adapter: ezsp
Zigbee2MQTT (V 1.39.1-1) Log:
[2024-08-18 21:38:19] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2024-08-18 21:38:19] info: 	z2m: Disconnecting from MQTT server
[2024-08-18 21:38:19] info: 	z2m: Stopping zigbee-herdsman...
[2024-08-18 21:38:19] error: 	z2m: MQTT error: read ECONNRESET
[2024-08-18 21:38:20] info: 	zh:controller: Wrote coordinator backup to '/config/zigbee2mqtt/coordinator_backup.json'
[2024-08-18 21:38:20] info: 	z2m: Stopped zigbee-herdsman
[2024-08-18 21:38:20] info: 	z2m: Stopped Zigbee2MQTT
[21:44:16] INFO: Preparing to start...
[21:44:21] INFO: Socat not enabled
[21:44:27] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-08-18 21:45:03] info: 	z2m: Logging to console, file (filename: log.log)
[2024-08-18 21:45:03] info: 	z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-18 21:45:03] info: 	z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-18 21:45:07] warning: 	zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2024-08-18 21:45:15] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":1} after 4000ms
[2024-08-18 21:45:15] error: 	zh:ezsp:uart: -!- break waiting (1)
[2024-08-18 21:45:15] error: 	zh:ezsp:uart: Can't send DATA frame (0,0,0): 00000004
[2024-08-18 21:45:20] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":1} after 4000ms
[2024-08-18 21:45:20] error: 	zh:ezsp:uart: -!- break rewaiting (1)
[2024-08-18 21:45:20] error: 	zh:ezsp:uart: Can't resend DATA frame (0,0,1): 00000004
[2024-08-18 21:45:20] error: 	z2m: Error while starting zigbee-herdsman
[2024-08-18 21:45:20] error: 	z2m: Failed to start zigbee
[2024-08-18 21:45:20] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-08-18 21:45:20] error: 	z2m: Exiting...
[2024-08-18 21:45:22] error: 	z2m: Error: Failure send version:{"type":"Buffer","data":[0,0,0,4]}
    at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:675:23
    at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
    at Ezsp.version (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:457:24)
    at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:185:9)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
    at Zigbee.start (/app/lib/zigbee.ts:63:27)
    at Controller.start (/app/lib/controller.ts:139:27)
    at start (/app/index.js:154:5)
[21:45:37] INFO: Preparing to start...
[21:45:41] INFO: Socat not enabled
[21:45:49] INFO: Starting Zigbee2MQTT...
[2024-08-18 21:46:03] info: 	z2m: Logging to console, file (filename: log.log)
[2024-08-18 21:46:03] info: 	z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-18 21:46:03] info: 	z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-18 21:46:03] warning: 	zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2024-08-18 21:46:13] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-08-18 21:46:14] error: 	zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
    at SerialDriver.resetForReconnect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:341:19)
    at SerialDriver.emit (node:events:517:28)
    at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:344:22
    at SerialDriver.openSerialPort (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:106:13)
    at SerialDriver.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:61:13)
    at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:347:17)
    at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:176:13)
[2024-08-18 21:46:29] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-08-18 21:46:29] error: 	zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
[2024-08-18 21:46:49] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-08-18 21:46:49] error: 	zh:ezsp:ezsp: Connection attempt 3 error: Error: Failure to connect
[2024-08-18 21:47:15] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":5} after 4000ms
[2024-08-18 21:47:15] error: 	zh:ezsp:uart: -!- break waiting (5)
[2024-08-18 21:47:15] error: 	zh:ezsp:uart: Can't send DATA frame (4,4,0): 04000153001d3200
[2024-08-18 21:47:26] error: 	zh:ezsp:ezsp: setConfigurationValue(29, 50) error: Error: Failure send setConfigurationValue:{"type":"Buffer","data":[4,0,1,83,0,29,50,0]} Error: Failure send setConfigurationValue:{"type":"Buffer","data":[4,0,1,83,0,29,50,0]}
    at Ezsp.setConfigurationValue (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:511:21)
    at Ezsp.updateConfig (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:608:17)
    at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:186:9)
[2024-08-18 21:47:30] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":6} after 4000ms
[2024-08-18 21:47:30] error: 	zh:ezsp:uart: -!- break waiting (6)
[2024-08-18 21:47:30] error: 	zh:ezsp:uart: Can't send DATA frame (5,1,0): 0500010500
[2024-08-18 21:47:34] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":6} after 4000ms
[2024-08-18 21:47:34] error: 	zh:ezsp:uart: -!- break rewaiting (6)
[2024-08-18 21:47:34] error: 	zh:ezsp:uart: Can't resend DATA frame (5,1,1): 0500010500
[2024-08-18 21:47:34] error: 	zh:ezsp:ezsp: Watchdog heartbeat timeout Error: Failure send nop:{"type":"Buffer","data":[5,0,1,5,0]}
    at Ezsp.watchdogHandler (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:781:13)
Mosquitto broker (V 6.4.1) Configuration:
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: false
  folder: mosquitto
Mosquitto broker (V 6.4.1) Log:
2024-08-18 21:21:16: New connection from 172.30.32.2:38820 on port 1883.
2024-08-18 21:21:16: Client <unknown> closed its connection.
2024-08-18 21:23:16: New connection from 172.30.32.2:59508 on port 1883.
2024-08-18 21:23:16: Client <unknown> closed its connection.
2024-08-18 21:25:16: New connection from 172.30.32.2:54166 on port 1883.
2024-08-18 21:25:16: Client <unknown> closed its connection.
2024-08-18 21:27:16: New connection from 172.30.32.2:40468 on port 1883.
2024-08-18 21:27:16: Client <unknown> closed its connection.
2024-08-18 21:29:16: New connection from 172.30.32.2:54942 on port 1883.
2024-08-18 21:29:16: Client <unknown> closed its connection.
2024-08-18 21:31:16: New connection from 172.30.32.2:57186 on port 1883.
2024-08-18 21:31:16: Client <unknown> closed its connection.
2024-08-18 21:33:16: New connection from 172.30.32.2:38404 on port 1883.
2024-08-18 21:33:16: Client <unknown> closed its connection.
2024-08-18 21:35:04: Saving in-memory database to /data//mosquitto.db.
2024-08-18 21:35:16: New connection from 172.30.32.2:47666 on port 1883.
2024-08-18 21:35:16: Client <unknown> closed its connection.
2024-08-18 21:37:16: New connection from 172.30.32.2:38710 on port 1883.
2024-08-18 21:37:16: Client <unknown> closed its connection.
s6-rc: info: service legacy-services: stopping
2024-08-18 21:38:19: mosquitto version 2.0.18 terminating
time="2024-08-18T21:38:19+05:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": read tcp 127.0.0.1:54952->127.0.0.1:80: read: connection reset by peer"
time="2024-08-18T21:38:19+05:00" level=error msg="POST error: Post \"http://127.0.0.1:80/acl\": dial tcp 127.0.0.1:80: connect: connection refused"
time="2024-08-18T21:38:19+05:00" level=error msg="Post \"http://127.0.0.1:80/superuser\": read tcp 127.0.0.1:54952->127.0.0.1:80: read: connection reset by peer"
2024-08-18 21:38:19: Saving in-memory database to /data//mosquitto.db.
[16:38:20] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[21:42:51] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[21:42:55] INFO: Starting NGINX for authentication handling...
[21:42:55] INFO: Starting mosquitto MQTT broker...
2024-08-18 21:42:55: Warning: Mosquitto should not be run as root/administrator.
2024-08-18 21:42:55: mosquitto version 2.0.18 starting
2024-08-18 21:42:55: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-08-18 21:42:55: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-08-18 21:42:55:  ├── Username/password checking enabled.
2024-08-18 21:42:55:  ├── TLS-PSK checking enabled.
2024-08-18 21:42:55:  └── Extended authentication not enabled.
2024-08-18 21:42:55: Opening ipv4 listen socket on port 1883.
2024-08-18 21:42:55: Opening ipv6 listen socket on port 1883.
2024-08-18 21:42:55: Opening websockets listen socket on port 1884.
2024-08-18 21:42:55: mosquitto version 2.0.18 running
2024-08-18 21:42:58: New connection from ::1:34512 on port 1883.
2024-08-18 21:42:58: Client <unknown> disconnected due to protocol error.
[21:43:01] INFO: Successfully send discovery information to Home Assistant.
[21:43:03] INFO: Successfully send service information to the Supervisor.
2024-08-18 21:43:52: New connection from 172.30.32.1:54955 on port 1883.
2024-08-18 21:43:52: New client connected from 172.30.32.1:54955 as 2TFuRsshMFf4wTr2depG2M (p2, c1, k60, u'mqttuser').
2024-08-18 21:46:56: New connection from 172.30.32.2:58714 on port 1883.
2024-08-18 21:46:56: Client <unknown> closed its connection.
2024-08-18 21:48:56: New connection from 172.30.32.2:35176 on port 1883.
2024-08-18 21:48:56: Client <unknown> closed its connection.
2024-08-18 21:50:56: New connection from 172.30.32.2:42022 on port 1883.
2024-08-18 21:50:56: Client <unknown> closed its connection.
2024-08-18 21:52:56: New connection from 172.30.32.2:55656 on port 1883.
2024-08-18 21:52:56: Client <unknown> closed its connection.
2024-08-18 21:54:56: New connection from 172.30.32.2:55532 on port 1883.
2024-08-18 21:54:56: Client <unknown> closed its connection.
2024-08-18 21:56:56: New connection from 172.30.32.2:40526 on port 1883.
2024-08-18 21:56:56: Client <unknown> closed its connection.
2024-08-18 21:58:56: New connection from 172.30.32.2:46754 on port 1883.
2024-08-18 21:58:56: Client <unknown> closed its connection.
2024-08-18 22:00:56: New connection from 172.30.32.2:59006 on port 1883.
2024-08-18 22:00:56: Client <unknown> closed its connection.
2024-08-18 22:02:56: New connection from 172.30.32.2:56400 on port 1883.
2024-08-18 22:02:56: Client <unknown> closed its connection.
2024-08-18 22:04:56: New connection from 172.30.32.2:48954 on port 1883.
2024-08-18 22:04:56: Client <unknown> closed its connection.
2024-08-18 22:06:56: New connection from 172.30.32.2:37124 on port 1883.
2024-08-18 22:06:56: Client <unknown> closed its connection.
2024-08-18 22:08:56: New connection from 172.30.32.2:55694 on port 1883.
2024-08-18 22:08:56: Client <unknown> closed its connection.
2024-08-18 22:10:56: New connection from 172.30.32.2:49112 on port 1883.
2024-08-18 22:10:56: Client <unknown> closed its connection.
2024-08-18 22:12:56: New connection from 172.30.32.2:41690 on port 1883.
2024-08-18 22:12:56: Client <unknown> closed its connection.
2024-08-18 22:12:58: Saving in-memory database to /data//mosquitto.db.
2024-08-18 22:14:56: New connection from 172.30.32.2:57066 on port 1883.
2024-08-18 22:14:56: Client <unknown> closed its connection.
2024-08-18 22:16:56: New connection from 172.30.32.2:42998 on port 1883.
2024-08-18 22:16:56: Client <unknown> closed its connection.
HA Core Log:
2024-08-18 21:44:05.334 WARNING (MainThread) [zigpy.application] Zigbee channel 11 utilization is 96.64%!
2024-08-18 21:44:05.334 WARNING (MainThread) [zigpy.application] If you are having problems joining new devices, are missing sensor updates, or have issues keeping devices joined, ensure your coordinator is away from interference sources such as USB 3.0 devices, SSDs, WiFi routers, etc.
2024-08-18 21:45:11.545 WARNING (MainThread) [bellows.ezsp.protocol] Unknown application frame 0x0208 received: b'306a' (b'0080000802306a').  This is a bug!
2024-08-18 21:45:19.372 WARNING (MainThread) [bellows.zigbee.application] Watchdog heartbeat timeout: TimeoutError()
2024-08-18 21:45:22.277 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-08-18 21:45:24.347 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
  File "/usr/local/lib/python3.12/site-packages/bellows/ash.py", line 631, in _send_data_frame
    await ack_future
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.12/site-packages/bellows/ash.py", line 630, in _send_data_frame
    async with asyncio_timeout(self._t_rx_ack):
  File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
2024-08-18 21:45:37.514 WARNING (MainThread) [zigpy.application] Zigbee channel 11 utilization is 97.39%!
2024-08-18 21:45:37.532 WARNING (MainThread) [zigpy.application] If you are having problems joining new devices, are missing sensor updates, or have issues keeping devices joined, ensure your coordinator is away from interference sources such as USB 3.0 devices, SSDs, WiFi routers, etc.
2024-08-18 21:46:05.080 WARNING (bellows.thread_0) [bellows.uart] Received an unexpected reset: <NcpResetCode.RESET_SOFTWARE: 11>
2024-08-18 21:46:09.081 WARNING (MainThread) [bellows.zigbee.application] Watchdog heartbeat timeout: InvalidCommandError('readCounters command is an invalidCommand, was sent under 106 sequence number: ERROR_VERSION_NOT_SET')
2024-08-18 21:46:19.104 WARNING (MainThread) [bellows.zigbee.application] Watchdog heartbeat timeout: InvalidCommandError('readCounters command is an invalidCommand, was sent under 107 sequence number: ERROR_VERSION_NOT_SET')
2024-08-18 21:46:20.770 WARNING (bellows.thread_0) [bellows.uart] Received an unexpected reset: <NcpResetCode.RESET_SOFTWARE: 11>
2024-08-18 21:46:29.124 WARNING (MainThread) [bellows.zigbee.application] Watchdog heartbeat timeout: InvalidCommandError('readCounters command is an invalidCommand, was sent under 108 sequence number: ERROR_VERSION_NOT_SET')
2024-08-18 21:46:39.139 WARNING (MainThread) [bellows.zigbee.application] Watchdog heartbeat timeout: InvalidCommandError('readCounters command is an invalidCommand, was sent under 109 sequence number: ERROR_VERSION_NOT_SET')
2024-08-18 21:46:40.829 WARNING (bellows.thread_0) [bellows.uart] Received an unexpected reset: <NcpResetCode.RESET_SOFTWARE: 11>
2024-08-18 21:46:49.161 WARNING (MainThread) [bellows.zigbee.application] Watchdog heartbeat timeout: InvalidCommandError('readCounters command is an invalidCommand, was sent under 110 sequence number: ERROR_VERSION_NOT_SET')
2024-08-18 21:46:49.161 WARNING (MainThread) [zigpy.application] Watchdog failure
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 665, in _watchdog_loop
    await self.watchdog_feed()
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 651, in watchdog_feed
    await self._watchdog_feed()
  File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 893, in _watchdog_feed
    current_counters = await self._ezsp.read_counters()
  File "/usr/local/lib/python3.12/site-packages/bellows/ezsp/v4/__init__.py", line 190, in read_counters
    (res,) = await self.readCounters()
  File "/usr/local/lib/python3.12/site-packages/bellows/ezsp/protocol.py", line 76, in command
    return await future
bellows.exception.InvalidCommandError: readCounters command is an invalidCommand, was sent under 110 sequence number: ERROR_VERSION_NOT_SET
2024-08-18 21:46:58.710 WARNING (MainThread) [zigpy.application] Zigbee channel 11 utilization is 97.04%!
2024-08-18 21:46:58.711 WARNING (MainThread) [zigpy.application] If you are having problems joining new devices, are missing sensor updates, or have issues keeping devices joined, ensure your coordinator is away from interference sources such as USB 3.0 devices, SSDs, WiFi routers, etc.
2024-08-18 21:47:15.133 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2024-08-18 21:47:19.262 ERROR (bellows.thread_0) [bellows.uart] Lost serial connection: SerialException('device reports readiness to read but returned no data (device disconnected or multiple access on port?)')
2024-08-18 21:47:19.291 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry SONOFF Zigbee 3.0 USB Dongle Plus V2 for zha
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 604, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 151, in async_setup_entry
    await zha_gateway.async_initialize()
  File "/usr/local/lib/python3.12/site-packages/zha/application/gateway.py", line 273, in async_initialize
    await self._async_initialize()
  File "/usr/local/lib/python3.12/site-packages/zha/application/gateway.py", line 256, in _async_initialize
    await self.application_controller.startup(auto_form=True)
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 233, in startup
    await self.connect()
  File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 148, in connect
    await ezsp.startup_reset()
  File "/usr/local/lib/python3.12/site-packages/bellows/ezsp/__init__.py", line 128, in startup_reset
    await self.version()
  File "/usr/local/lib/python3.12/site-packages/bellows/ezsp/__init__.py", line 174, in version
    ver, stack_type, stack_version = await self._command(
  File "/usr/local/lib/python3.12/site-packages/bellows/ezsp/__init__.py", line 221, in _command
    return await command(*args, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/bellows/ezsp/protocol.py", line 75, in command
    await self._gw.send_data(data)
Stop Zigbee2MQTT, Unplug your dongle, and plug it back in, start Zigbee2MQTT
This is a ZHA error message. ZHA and Zigbee2MQTT are fighting for control over the dongle. If you have one dongle, you can run Zigbee2MQTT OR ZHA, not both.
I am using Zigbee2MQTT add-on on my HA. This is how it has been running for a few months. But now it stopped.
I’ll try this out.
I tried it, but it didn’t help.
Make sure ZHA is uninstalled. The error
means ZHA is still messing with the dongle.
I went to Settings - > Devices and Services → Integrations found the Zigbee Home Automation and deleted it. Then I restarted the HA and that fixed the error. I had to reconfigure my smart switches though.
Thanks for the help.
