Unable to create sensor template
I have this in my config.yaml
sensor: !include sensors.yaml
And this in my sensors.yaml file
      sensors:
        alarm_arm_status:
          value_template: >-
            {% if states.binary_sensor.alarm_arm_status.state == 'off' %}
              Disarmed
            {% elif states.binary_sensor.alarm_arm_status.state == 'on' %}
              Armed
          icon_template: >
              mdi:lock-open
              mdi:lock
I keep getting error:
Configuration invalid
Error loading /config/configuration.yaml: mapping values are not allowed here
  in "/config/sensors.yaml", line 2, column 14
What is the correct way to update that sensor, Iā€™m sure my syntax is wrong
{% endif %} required in two places. You should specify an entity id to monitor for the template to update. Also you should capture the unknown state and use this form of template to avoid errors at start up:
    sensors:
      alarm_arm_status:
        entity_id: binary_sensor.alarm_arm_status
        value_template: >-
          {% if is_state('binary_sensor.alarm_arm_status', 'off') %}
            Disarmed
          {% elif is_state('binary_sensor.alarm_arm_status', 'on') %}
            Armed
          {% else %}
            Unknown
          {% endif %}
        icon_template: >
            mdi:lock-open
            mdi:lock
          {% else %}
            mdi:lock-alert
          {% endif %}
Also, check the indentation for everything after the first line. It all needs moved back to the left 4 spaces in your first post and 2 spaces in toms post.
Thanks, I believe I have it right but again the same error
Seems to be because of this guy:
Is the indentation still wrong? Looks good in VS code
sensors: should be at the same indentation level as platform: Sorry. I copied your error.
Should be:
  sensors:
    alarm_arm_status:
      value_template: >-
          Disarmed
          Armed
        {% else %}
          Unknown
        {% endif %}
      icon_template: >
          mdi:lock-open
          mdi:lock
        {% else %}
          mdi:lock-alert
        {% endif %}
ā€œmapping values not allowed hereā€ is nearly always an indentation problem.
Yup that was it, thanks
But it looks like the icon part worked ok but the value did not, still showing Open/Closed
I assumed the Open above should be changed with Armed?
The icon is not correct either. Thatā€™s a shield not a lock.
Are you sure you have the correct sensor?
It should be: sensor.alarm_arm_status
I forgot I have this in my customize.yaml
binary_sensor.alarm_arm_status:
        icon: mdi:shield-check
But yeah I remove that and the icon does not work either
And yeah the name looks good
No, it does not.
not
Still no joy :frowning:
  sensors:
    alarm_arm_status:
      entity_id: sensor.alarm_arm_status
      value_template: >-
        {% if is_state('sensor.alarm_arm_status', 'off') %}
          Disarmed
        {% elif is_state('sensor.alarm_arm_status', 'on') %}
          Armed
        {% else %}
          Unknown
        {% endif %}
      icon_template: >-
          mdi:lock-open
          mdi:lock
        {% else %}
          mdi:lock-alert
        {% endif %}
Sure it is not with the binary in front like in the card?
No, no, no.
Donā€™t change the sensor template. Put that back to using the binary sensor.
Then put this in an entities card in the front end:
not
You made a template sensor not a template binary sensor.
Sorry, getting confused thought the template was just being applied to the binary sensor and not creating a new one, however I cannot find the new one in the entity list
  sensors:
    alarm_arm_status:
      value_template: >-
          Disarmed
          Armed
        {% else %}
          Unknown
        {% endif %}
      icon_template: >-
          mdi:lock-open
          mdi:lock
        {% else %}
          mdi:lock-alert
        {% endif %}
I appreciate the help, I think Iā€™m making this harder than it is
You missed one
  sensors:
    alarm_arm_status:
      entity_id: binary_sensor.alarm_arm_status  #### <-----HERE
      value_template: >-
          Disarmed
          Armed
        {% else %}
          Unknown
        {% endif %}
      icon_template: >-
          mdi:lock-open
          mdi:lock
        {% else %}
          mdi:lock-alert
        {% endif %}
All of this should be in your sensors.yaml file. Not binary_sensors.yaml
Tried that too and same but I reckon my config.yaml is the issue
At the top:
And I found this later on
I am guessing it is totally ignoring my sensors file because of the other sensor mention? Going to try and put all of them in the file and see if it fixes it
Thatā€™s bad.
Move all the config below that sensors: (minus sensors:, delete that) to your sensors.yaml file.
you should only have one sensors: in your configuration.yaml file and thatā€™s the one pointing to sensors.yaml.
Yeah I was expecting the usual error cannot have multiple sensors etc
Tried the most basic example from https://www.home-assistant.io/components/template/ and just cannot get past the indentation error I think
my sensors.yaml file currently
      sensors:
        - solar_angle:
            friendly_name: "Sun angle"
            unit_of_measurement: 'degrees'
            value_template: "{{ state_attr('sun.sun', 'elevation') }}"
config.yaml
And same error
I know that this works fine directly in config.yaml since I can see the new sun sensor in the entity list
    sensors:
      solar_angle:
The two sensor configs you posted are different.
This is wrong:
      sensors: ##### <-----  you indented this again.
        - solar_angle: ################ <-- remove the dash, fix the indentation
This is right:
  sensors:
    solar_angle:
Thereā€™s two types of multiple item objects. Lists, that use ā€œ-ā€ and maps that dont.
Template sensors are maps, not lists. See the ā€œ(map)ā€ in the documentation, https://www.home-assistant.io/components/template/#sensors
Worked it out thanks, it was a combination of - and the sensors: under - platform that was not indented properly. Never thought Iā€™d say it but I think I prefer JSON :smiley:
One more question, the status of the new sensor.alarm_arm_status doesnā€™t seem to be instantly updated when the state of binary_sensor.alarm_arm_status changes. Any idea why?
