I cannot remove a former tradfri switch from the device list. The switch is physically dead (RIP), so I cannot repair to remove it. I have no IEEE address to try a zha.delete
Do you have suggestions to remove this ? Edit the zigbee.db ?
I had similar issue and had to remove if from core.device_registry file, carefully (and took a back up first
Emphasis on carefully! I made the mistake of leaving a rogue ; in the file and it caused HA to not load the GUI. Luckily I could access the files via Samba and edit.
I suggest copy / pasting the contents into a JSON validator prior to saving your changes
That’s not the a Tradfri, that’s your coordinator (RaspBee)
What do you mean? The issue should be fixed on the raspbee?
I edited the JSON and the device is gone.
Thanks!
No, that was your Raspbee/coordinator/PiHat/Zigbee shield. … Not a Tradfri at all, look at the lower lines in your original screenshot. It shouldn’t hurt anything with you manually taking it out, but it’s just a bit of a bug now that it gets marked as unavailable at all.
On all my devices it shows the coordinator’s name where it is shown above, this is an example of one of my devices
There is no option to remove device on the coordinator
