Unable to Delete Google Nest integration
Hey Guys and girls,
My Google Nest integration has stop working and after some troubleshooting, I decided to reconfigure it from scratch. The problem is I cannot delete the integration to remove to old devices / entitiies. I have the delete options but when I click it it is simply not deleted.
I’ve also tried to delete my application credentials first, but I am unable to remove them since they are still in use by the integration which I am unable to remove…
Any help in removing the integration so I can reinitiate the setup are apriciated.
Anyone? I really need to get it deleted to reconfigure it.
You could stop HA and manually edit the .storage/core.config_entries and remove the entry
Make a backup first
How does one do this? I run HA on a bare metal thin client PC. From file editor or studio code server I cannot see that file path.
It may be hidden, it is there. I use WINSCP to connect to ha file system.
This broke HA for me, so don’t advise this xd
I’ll be debugging tonight I guess
I’d guess you mis edited and made the file not valid json.
Well, if the JSON wasn’t valid, usually HA detects it. It booted eventually, just took a very long time (effectively couple of hours). Rebooted immediately after and then it all worked out.
