I moved my HassOS installation from an Raspberry Pi to a a virtualized environment. For setup I used the following script https://github.com/tteck/Proxmox/raw/main/vm/haos-vm.sh which pulls the official KVM (qcow2) disk image.
On the RPi I always had problems with RAM, so I dedicated quite a lot diskspace for swapping. As I am now filled with RAM I wanted to disable the swap.
But I have no idea how I could do that… swapoff -a didn’t disabled it, and I see in /procs/swap that a swapfile should live under /mnt/data/swap. I also saw a hassos swap job on boot, but I might to be too stupid to link this information together.
That’s not how swap works. The OS will use it preemptively even if it isn’t needed. I have a box running proxmox with an SSD in it that was at 15% wearout and had been for months. I ran an HAOS virtual machine on it for 2 weeks with 8GB ram allocated, and after 2 weeks the SSD was at 21% wearout. That’s killing an SSD a year.
The “we know better than you” attitude of this community and HAOS itself is insulting and counterproductive. Feedback like this is important to listen to.
