I’m installing Home Assistant on Pi4. After instalation of the image, setup Pi4 with ethernet cable and power suply. After boot of Pi4 on Home Assistant URL i get this error:
23-08-14 13:41:52 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.1: 500 Server Error for http+docker://localhost/v1.42/images/create?tag=2023.08.1&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/sha256:1995a72b8d0fbd3feba385848f689e9456980845eb054e0bc12937b4e7a43873": dial tcp 140.82.121.34:443: connect: no route to host")
23-08-14 13:41:52 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.SUPERVISOR / None
23-08-14 13:41:52 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.1: 500 Server Error for http+docker://localhost/v1.42/images/create?tag=2023.08.1&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/sha256:1995a72b8d0fbd3feba385848f689e9456980845eb054e0bc12937b4e7a43873": dial tcp 140.82.121.34:443: connect: no route to host")
23-08-14 13:41:52 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
Restarted multiple times, still same issue. Thank you, for any help, addicional information.
There was a note that stated the architecture images are no longer being released. You must use the ghcr.io/homeassistant/home-assistant:stable or ghcr.io/homeassistant/home-assistant:latest or ghcr.io/homeassistant/home-assistant:YYYY.MM.## image tags.
Update: Now installed HA release from github and getting this:
23-08-14 15:21:32 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.8.2: 500 Server Error for http+docker://localhost/v1.42/images/create?tag=2023.8.2&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/raspberrypi4-64-homeassistant/manifests/2023.8.2": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fraspberrypi4-64-homeassistant%3Apull&service=ghcr.io": dial tcp 140.82.121.34:443: connect: no route to host")
