Hi. Total newbie here.
I have a Hassio running on a Raspberry, ethernet connected.
I’ve successfully enabled SMB, and I CAN edit configuration.yaml
I’ve tried to add Netatmo thermostat and sensor as told in the help, and even started from scratch following the “random sensor” in the installation guide.
Each and every time I edit the .yaml file and I restart the raspberry, no frontend is started.
I have to revert back to a previous sconfiguration.yaml where I changed only the coordinates to make myip:8123 available again.
After using Yamlint -I didn’t know it-, correcting some spaces/tabs, here the resulting log
2017-11-06 20:49:46 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
in "/config/configuration.yaml", line 1, column 1
expected <block end>, but found '<block mapping start>'
in "/config/configuration.yaml", line 84, column 3
2017-11-06 20:49:46 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
The first error is the worst, seen I didn’t touch the start of the configuration.yaml (row 1 column 1 isnt’t the real start of the file?)
Now I have to understand what a and are and how to change one for another
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 43.xxxx
longitude: 11.xxxx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 35
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Rome
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
# api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
group: !include groups.yaml
automation: include automations.yaml
script: !include scripts.yaml
- platform: random
netatmo:
api_key: xxxxxx
secret_key: xxxxxxx
username: [email protected]
password: xxxxxxx
platform: netatmo
station: Tardis
modules:
Esterno:
- temperature
- battery_vp
- humidity
- pressure
Interno:
- temperature
- battery_vp
- humidity
- co2
Interno2:
- temperature
- battery_vp
- humidity
- co2
Pluviometro:
- sum_rain_1
climate:
- platform: netatmo
Your indent on line 84 (Esterno:) was incorrect. Hass is extremely tempermental about formatting, especially indents and spacing. Indentations must always be 2 spaces, no more, no less. You should also only use uppercase letters in friendly names, as hass will convert them to lowercase anyway.
homeassistant:
latitude: 43.xxxx
longitude: 11.xxxx
elevation: 35
unit_system: metric
introduction:
frontend:
config:
http:
updater:
discovery:
conversation:
history:
logbook:
map:
# Track the sun
sun:
- platform: yr
# Text to speech
tts:
- platform: google
- platform: random
netatmo:
api_key: xxxxxx
secret_key: xxxxxxx
password: xxxxxxx
platform: netatmo
station: Tardis
modules:
esterno:
- temperature
- battery_vp
- humidity
- pressure
interno:
- temperature
- battery_vp
- humidity
- co2
interno2:
- temperature
- battery_vp
- humidity
- co2
pluviometro:
- sum_rain_1
climate:
- platform: netatmo
thank you all, I have come to the same conclusion while Bahnburner was writing.
Now I am retrieving (and, don’t know why, displaying) all the data from all the sensors.
Another day, another problem
