I’m unable to edit the friendly name of my sensors in zigbee2mqtt. Just have setup a new installation and on my previous installation I don’t recall this issue. I have also tried removing the sensor from home-assistant, hoping I was able to edit then.
you should give us the error log . and you maybe, should use the zigbee2mqtt frontend.
http://z2m.ipaddress:8180
How did you try to change them ?
I’m using z2m as hassio addon and installed it using the repository. There I’m going to the sensor setting and want to adjust the friendly name there, which is a greyed out text field. Error logs are empty.
Owkey. Totally overlooked this.
So i was able to do this for all of my devices except my newest one, the blue button no longer shows up for any device
It is a bug that will be fixed in the next version
For reference:
On iOS the blue button doesn’t show up in portrait mode either. Flipping the phone on it’s side to landscape makes it show up (at least on iOS).
