Unable to find how to get HA to tell me what time it is
I can ask Alexa “Alexa, what time is it?” and I get a reply. I am trying to do this disconnected from the internet. Does anybody have an idea? I am new to Home Assistant but I can voice control my lights.
Are you using Alexa to voice control your lights? If so do you have a Home Assistant Cloud subscription, or are you using a custom integration?
I am moving over to HA from Alexa. I am in a high risk zone for hurricanes and go without internet for too long. I am using HA for what Alexa once did for me.
I am older, handicapped and live alone. I am trying to automate everything I can as soon as I can, Thank you for any help. Once I get a few tasks under my belt I should be able to modify more for other uses.
I have setup date/time as a helper but so many instructions over the web involve hardware I dont have. My server has date/time I thought it would be easy to send a “now” time to TTS to get current time but I dont know how to do that.
I use Piper text to speech and it works very well over my RaspiAudio Muse Luxe. Not sure where or if this would work “The time is {{ now().strftime(‘%H %M’) }}”
I use an HA automation that says “X minutes after Y pm” or “X minutes until Y am.”
alias: Assist Tell Time
description: Voice Assistant Tell the Time
  - platform: conversation
    command:
      - What is the time
      - Tell me the time
      - What time is it
      - Give me the time
      - Time please
condition: []
  - set_conversation_response: |-
      {% set hour = now().hour %}
      {% set minute = now().minute %}
      {% set ampm = "AM" %}
      {% if hour > 12 %}
        {% set hour = hour - 12 %}
        {% set ampm = "PM" %}
      {% endif %}
      {% if minute < 30 %}
          The time is now {{minute}} minutes after {{hour}} {{ampm}}
      {% elif minute == 30 %}
          The time is now {{hour}} {{minute}} {{ampm}}
      {% elif minute > 30 %}
        {% set minute = 60 - now().minute %}
        {% set hour = hour + 1 %}
        {% if hour > 12 %}
        {% endif %}
      The time is now {{minute}} minutes before {{hour}} {{ampm}}
      {% endif %}
mode: single
Than you so much, this looks great! I have never done an automation or script before so I will have to figure out how and where to insert this, I will work on this best I can.
This is far more complicated than I ever expected, I never wanted to become a programmer. I was looking for something to help me out not a new career. I have to abandon my thought that Home Assistant was a replacement for Alexa. When I loose the internet II may be able to work my lights, still better than where I am today.
Thank you for your help! I stepped away for a few days, came back and had your automation running in 20 minutes. Sorry for being terse, some days are better than others
I’ve been playing around with this as well. This automation works, except that it doesn’t switch from AM to PM. I guess I can figure it out by where the sun is in the sky :rofl:
But in all seriousness… It would be nice to have it just simply announce the time in 24-hour format. Any idea how to do that? Nothing I’ve tried works and I’m also not a programmer…
I tried different things with these lines to at least get the AM/PM thing to work, but whatever I try I get a syntax error:
The YAML was written for my US/English/American system, generating 1-to-12 AM/PM responses.
If you prefer a simple 24-hour format, that isn’t terribly difficult:
      {% endif %}
OK, now I get it… Actually was able to make it say the time just in hours and minutes, either AM/PM format or 24-hour format!
Thank you
For all the dutch speaking people that come from the netherlands, i have written this YAML-code:
      {% if hour > 12 %}
      {% endif %}
      {% if hour == 0 %}
        Het is {{minute}} over {{hour + 12}}
      {% elif minute == 0 %}
        Het is {{hour}} uur
      {% elif minute == 15 %}
        Het is kwart over {{hour}}
      {% elif minute == 45 %}
        Het is kwart voor {{hour +1}}
      {% elif minute > 0 and minute < 15 %}
        Het is {{minute}} over {{hour}}
      {% elif minute > 15 and minute < 30 %}
        {% set minute = 30 - now().minute %}
        Het is {{minute}} voor half {{hour + 1}}
        Het is half {{hour +1}}
      {% elif minute > 30 and minute < 45 %}
        {% set minute = now().minute - 30 %}
        Het is {{minute}} over half {{hour +1}}
      {% elif minute > 45 and minute <= 60 %}
        Het is {{minute}} voor {{hour +1}}
      {% endif %}
