I would like to use kodi inside an automation but I am only getting the message: Service not found for call_service at pos 1: Unable to find service kodi/call_method
I have the following tried the follwing entry inside my automation.yaml:
Which version of home assistant are you using? The change from ‘media_player.kodi_call_method’ to ‘kodi.call_method’ was only recently in the 0.98 release. The error message looks like you are using an older version.
Is the service kodi.call_method listed in the services list in developer tools?
I am not sure what happens if you quit kodi while this method is called. Presumably the service disappears when kodi quits (unless you have another kodi media-player in HA.)
