Unable to find service script/doorsiren
Below is the script I have in my configuration.yaml file.
script:
doorsiren:
sequence:
- service: media_player.sonos_join
master: media_player.living_room
entity_id:
- media_player.living_room
- media_player.bedroom
- service: media_player.play_media
entity_id: media_player.living_room
media_content_id: Siren.mp3
media_content_type: music
Also, my automation calls it with:
- service: script.doorsiren
When I go to run the automation I am getting an Unable to find service script/doorsiren error in the log.
Can anyone tell what I am doing wrong?
Can you re-post using the preformatted text </>?
script.doorsiren looks like an entity id.
The service would be script.turn_on or one of the other services available for scripts.
script:
   doorsiren:
     sequence:
        entity_id:
In your automation use:
    - service: script.turn_on
      entity_id: script.doorsiren
gave that a try and got the following error now:
Unable to find service script/turn_on
Is script in your services list?
no, “Script” isn’t even listed as a domain
Have you restarted HA since adding it to your configuration.yaml?
Yea, I’ve restarted several times.
Any luck?
Can you post some of your config?
Maybe try the command hass --script check_config
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: !secret
  longitude: !secret
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: imperial
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: America/Chicago
  customize: !include customize.yaml
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
#sensor:
#  platform: yr
# Text to speech
tts:
  platform: google
zwave:
  usb_path: /dev/ttyACM0
  config_path: /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/libopenzwave-0.3.3-py3.4-linux-armv7l.egg/config
input_boolean:
  away_mode:
    name: Set Away Mode
    initial: off
nest:
  client_id: !secret
  client_secret: !secret
http:
 api_password: !secret
 ssl_certificate: !secret
 ssl_key: !secret
notify:
  - platform: pushbullet
    api_key: !secret
script:
   doorsiren:
     sequence:
        entity_id:
####  Includes  ###
group: !include groups.yaml
automation: !include automation.yaml
There is my entire config, not a lot going on. I can run the check config and it comes back as valid.
There are some spacing issues in your script. Not sure about the syntax of your first service either.
script:
  doorsiren:
    sequence:
        entity_id:
Tried it with the correct spacing and I’m still getting the same error.
I am facing the same issue
