I just purchased a new Inovelli 2nd gen light dimmer with LED notifications. The notification is set through a Z-Wave parameter. I’m able to set the LED color/intensity/effect through the “Developer Tools/Services” menu with the following parameters:
Service: zwave.set_config_parameter
Service Data (YAML, optional):
"node_id": 30,
"parameter": 16,
"size": 4,
"value": 50268725
However, trying to translate that into a simple automation does not work:
- alias: Bedroom LED indicator alarm
- platform: state
entity_id: group.all_locks
service: zwave.set_config_parameter
node_id: 30
parameter: 16
value: 50268725
I understand the automation isn’t finished, I was just trying to get any change in lock state to set the LED before I added more logic.
I get the following log entry in homeassistant.log:
2019-11-27 14:54:19 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.bedroom_led_indicator_alarm. Service not found for call_service at pos 1: Unable to find service zwave/set_config_parameter
Any thoughts? I’ve been up and down forums and it doesn’t seem like anyone else is having this issue. I’m currently running the following version in a virtual python environment:
Home Assistant 0.101.3
Thanks in advance for any possible help.
