Hi Folks,
I have setup my raspberry pi with several sensors connected to HA and everything works fine.
If I use WinSCP on my laptop, I can connect to the raspberryPi on my home wifi and find the configuration.yaml file at /home/hass/.homeassistant.
However, I have recently moved the whole setup to a remote site so the raspberry pi is no longer in my home network and I cant use WinSCP.
I am trying to use teamviewer to login into the raspberry pi, but I am unable to find the config file at that path. The path /home/hass is empty although I’m certain that the .homeassistant directory is inside.
HA is still running though.
So how do i see my config file?
