I have a lot of xiaomi aqara door sensors, movement sensors and buttons.
They all added to home assistant without any problem. But now i’m trying to add V1 (No aqara) door, movement and buttons to home assistant with the ZHA integration but i’m unable to add them (Also the deconz software doesnt find the device). They all seems to generate a time-out error or some sort.
Is there a way to fix this?
My Hardware.
HASS.IO docker on a synology Nas
Deconz II USB Stick
Log when searching for new devices and pressing the button on a door sensor (v1):
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [60, <Bool.false: 0>]
Device 0x0e47 (00:15:8d:00:04:1b:65:17) joined the network
[0x0e47:zdo] ZDO request ZDOCmd.Device_annce: [0x0E47, 00:15:8d:00:04:1b:65:17, 128]
[0x0e47] Requesting 'Node Descriptor'
Tries remaining: 2
[0x0e47] Extending timeout for 0xed request
Ignoring message (b'18000a050042126c756d692e73656e736f725f6d61676e6574') on cluster 0: unknown endpoint or cluster id: 1
Ignoring message (b'18010a0100200a') on cluster 0: unknown endpoint or cluster id: 1
Ignoring message (b'1c3412020a02ff4c0600100121bd0b21a80124000000000021eb06205f') on cluster 0: unknown endpoint or cluster id: 1
[0x0e47] Delivery error for seq # 0xed, on endpoint id 0 cluster 0x0002: message send failure
Tries remaining: 1
[0x0e47] Extending timeout for 0xef request
[0x0e47] Delivery error for seq # 0xef, on endpoint id 0 cluster 0x0002: message send failure
[0x0e47] Requesting Node Descriptor failed
[0x0e47] Discovering endpoints
Tries remaining: 3
[0x0e47] Extending timeout for 0xf1 request
[0x0e47] Delivery error for seq # 0xf1, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 2
[0x0e47] Extending timeout for 0xf3 request
[0x0e47] Delivery error for seq # 0xf3, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 1
[0x0e47] Extending timeout for 0xf5 request
[0x501a:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=True disable_default_response=True> manufacturer=4447 tsn=114 command_id=Command.Report_Attributes>
[0x501a:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=65281, value=<TypeValue type=CharacterString, value=(&!�>)]]
[0x501a:1:0x0000] Attribute report received: 65281=(&!�
[0x0e47] Delivery error for seq # 0xf5, on endpoint id 0 cluster 0x0005: message send failure
[0x0e47] Failed to discover active endpoints
[0x4bd7:1:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=171 command_id=Command.Report_Attributes>
[0x4bd7:1:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=Bool, value=Bool.false>)]]
[0x4bd7:1:0x0006] Attribute report received: on_off=0
[0xd14f:1:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=148 command_id=Command.Report_Attributes>
[0xd14f:1:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=Bool, value=Bool.false>)]]
[0xd14f:1:0x0006] Attribute report received: on_off=0
light.lumi_lumi_light_aqcn02_fe892a04_level_light_color_on_off: polling current state - from cache: False
[0x501a] Delivery error for seq # 0xf9, on endpoint id 1 cluster 0x0006: message send failure
[0xd14f] Delivery error for seq # 0x94, on endpoint id 1 cluster 0x0006: message send failure
[0x501a] Delivery error for seq # 0xfb, on endpoint id 1 cluster 0x0008: message send failure
[0x501a:1:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=253 command_id=Command.Read_Attributes_rsp>
1 have 7 v1 devices. So it would be a shame to trow them away.
