I am unable to upload the file to esp32. I must be doing something wrong.
I purchased a new ESP32. I am using the ESP32 add-on on HASSIO.
I plug in the ESP32 in the USB port where HASSIO is running.
Navigate to ESPHOME.
Select /dev/ttyACM0 from the dropdown (since it is a new esp32)
Click on upload.
Get this error.
INFO Reading configuration /config/esphome/shion_room_bed.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/bed_sensor
Processing bed_sensor (board: nodemcu-32s; framework: arduino; platform: [email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif32 3.10004.200129 (1.0.4)
- tool-esptoolpy 1.20600.0 (2.6.0)
- toolchain-xtensa32 2.50200.80 (5.2.0)
Dependency Graph
|-- <AsyncTCP-esphome> 1.1.1
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <FS> 1.0
|-- <ESPAsyncWebServer-esphome> 1.2.6
| |-- <FS> 1.0
| |-- <WiFi> 1.0
| |-- <ArduinoJson-esphomelib> 5.13.3
|-- <AsyncMqttClient-esphome> 0.8.4
|-- <DNSServer> 1.1.0
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Compiling /data/bed_sensor/.pioenvs/bed_sensor/src/main.cpp.o
Linking /data/bed_sensor/.pioenvs/bed_sensor/firmware.elf
Building /data/bed_sensor/.pioenvs/bed_sensor/firmware.bin
Retrieving maximum program size /data/bed_sensor/.pioenvs/bed_sensor/firmware.elf
Checking size /data/bed_sensor/.pioenvs/bed_sensor/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [= ] 13.0% (used 42712 bytes from 327680 bytes)
Flash: [===== ] 54.4% (used 891562 bytes from 1638400 bytes)
======================== [SUCCESS] Took 129.60 seconds ========================
INFO Successfully compiled program.
INFO Running: platformio run -d /config/esphome/bed_sensor -t upload --upload-port /dev/ttyACM0
PACKAGES:
- tool-mkspiffs 2.230.0 (2.30)
Dependency Graph
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <FS> 1.0
| |-- <FS> 1.0
| |-- <WiFi> 1.0
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Configuring upload protocol...
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Use manually specified: /dev/ttyACM0
Uploading /data/bed_sensor/.pioenvs/bed_sensor/firmware.bin
Serial port /dev/ttyACM0
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
*** [upload] Error 2
========================= [FAILED] Took 98.96 seconds =========================
In the ESPHome config file. It is blank. Am I suppose to add a line since I am connecting via usb?
Do I have a bad chip? I got this note from esphome site.
Note
If you’re just seeing Connecting....____.... on the screen and the flashing fails, that might be a sign that the ESP is defect or cannot be programmed. Please double check the UART wires are connected correctly if flashing using a USB to UART bridge. For some devices you need to keep pressing the BOOT button until flashing has begun (ie. Geekcreit DOIT ESP32 DEVKIT V1).
