I have a binary sensor rpi_gpio that is working as monitored on the overview screen in HA as ‘on’ and ‘off’. I have also confirmed the functionality by looking at the states (<>). I have added an !include automation.yaml file and have checked my config before restarting
group: !include groups.yaml
script: !include scripts.yaml
zone: !include zones.yaml
and added a simple webhook for my action.
# send a webhook as a test of home
- alias: 'gpio to trigger a webhook'
platform: state
entity_id: binary_sensor.alarm
to: 'on'
# state: 'on'
service: ifttt.trigger
event: MOTIONDETECT
in the states screen the automation shows up as follows (not sure if that is good or bad)
the webhook works properly as when I manually trigger the automation it is received in IFTTT
Before I move on to other automatons, I think I want to debug this simple one. I am able to trigger the binary at will and have tried it many times. What I would like to be able to do is trigger this automation via the GPIO and as a bonus, add an action that would send information to a log to help me debug in the future.
What does automation.gpio_to_trigger_a_webhook
look like on the States page?
EDIT: Wait. You provide a lot of detail, and make a bunch of statements, but you don’t ask a question or state a problem. What are you asking for help with?
this is what the states page looks like
which seems a bit odd since it says ‘on’. not sure I understand what that means yet.
below is the binary sensor state
the binary sensor will change from ‘off’ to ‘on’ at will
Problem. the binary sensor state changes from on to off and back on but never triggers any automation. I would like it to trigger the automation noted so I must have something incorrect and could use help.
bonus for me would be for someone to help me add an action so that when any automation or is successful it logs somewhere where i can have access. this will help me debug in the future.
An automation’s state (on
or off
) controls whether or not it will monitor its triggers/conditions and run its actions when the triggers/conditions “fire.” So, if the automation is off
, then it won’t do anything. It has to be on
in order to do anything. Since yours shows that it’s on
, that’s good.
The automation is currently configured to trigger if binary_sensor.alarm
goes from off
to on
. However, you seem to imply you want it to trigger if binary_sensor.pir_alarm
goes from off
to on
. If so, you need to change the entity_id
in the automation’s trigger
from binary_sensor.alarm
to binary_sensor.pir_alarm
There are already three logging systems that exist that can provide this information. See Logbook, Logger & System Log.
This is perfect. Thanks for the help as changing the 'entity_idin the automation’s
triggerfrom
binary_sensor.alarmto
binary_sensor.pir_alarm` was the fix. This will help me with all future automatons so thanks again
