Unable to get automations to work on a Z-Wave Multilevel Wallswitch
My setup: Raspberry Pi 4 with original HA Image
Home Assistant 2022.9.5 Supervisor 2022.09.1 Operating System 9.0 Frontend 20220907.2 - latest
Mosquitto broker 6.1.3
Aeotec Z-Stick 7 ZWA010 FW 7.17.2
tested with Z-Wave JS 0.1.71 and Z-Wave JS to MQTT 0.47.0
The device:
6 way Vitrum VI Satellite Wireless (01E060041)
the six buttons can be set to 3 modes, tested the 3 modes
dimmer association - on-off switch association - on-off push button association
In Dev Tool the state updates only if i use the HA Dashboard
The physical buttons update state colors correctly when using HA
no reaction on HA when pushing the physical buttons (only physical color change)
pushing button 5 log:
Subscribed to Z-Wave JS Log Messages…
Log Level changed to: Silly
2022-09-22T08:22:19.543Z SERIAL « 0x011100a806010508600a051100268672009171 (19 bytes)
2022-09-22T08:22:19.554Z SERIAL » [ACK] (0x06)
2022-09-22T08:22:19.561Z CNTRLR [Node 005] [translateValueEvent: value updated]
commandClass: Multi Channel
endpoint: 5
property: deviceClass
propertyKey: undefined
internal: true
secret: false
event source: undefined
2022-09-22T08:22:19.563Z CNTRLR [Node 005] [~] [Multi Channel] deviceClass: {“generic” [Endpoint 5] [internal]
:17,“specific”:0} => {“generic”:17,“specific”:0}
2022-09-22T08:22:19.566Z CNTRLR [Node 005] [translateValueEvent: value updated]
endpoint: 5
property: commandClasses
internal: true
secret: false
2022-09-22T08:22:19.567Z CNTRLR [Node 005] [~] [Multi Channel] commandClasses: 38,134, [Endpoint 5] [internal]
114 => 38,134,114
2022-09-22T08:22:19.571Z DRIVER « [Node 005] [REQ] [BridgeApplicationCommand]
│ type: broadcast
│ target node: 255
│ RSSI: -111 dBm
└─[MultiChannelCCCapabilityReport]
endpoint index: 5
generic device class: Multilevel Switch
specific device class: Unused
is dynamic end point: false
supported CCs:
· Multilevel Switch
· Version
· Manufacturer Specific
with Z-Wave JS to MQTT, i can see currentValue and targetValue change (0.0 when OFF 99.255 when ON)
but again MQTT Explorer updates the values only when using HA Dashboard
if i use physical button, i need to click manually on refresh to the values to update
any advice ? am new to smart home, and need to get these old device to work…
many thanks
François
Hello. now I understood the problem
the device is not sending any update… (old device)
I need to poll it each time
I got it working with this information link
but it is not clean at all to poll all devices every 10 sec. 10 sec is the minimum. and still long…
is there a way to trigger polling on any z-wave activity ?
