Unable to get current_temperature from HeatIt Z-wave thermostat
This is my code for the TF056 that works.
	<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="5">
				<Instance index="1" endpoint="3" />
				<Value type="decimal" genre="user" instance="1" index="0" label="External sensor" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.0" />
				<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.4" />
				<Value type="decimal" genre="user" instance="2" index="1" label="Floor sensor" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="22.5" />
			</CommandClass>
Stopped HA. Replaced my ā€œCommandClassā€ text with yours and it seems to be working now! Thanks a lot @Magren !
I also have this card just to get the statistics on the thermostat etc.
SkƤrmklipp
How did you @Magren @str2der manage to change the zwcfg.xml file? If I change the file it will change back when I start HA. What I tried with the ssh add-on:
  1. ha core stop
  2. change file
  3. ha core start
  1. ha core stop
  2. change file
  3. ha core reboot
  1. stop zwave network in UI
  2. change file
  3. ha core reboot
I had success doing as described, but about two days ago, things went back to the original state. Showing 0 degrees.
Haven’t been searching or testing anything since then.
Ok for now I use:
Once again did the hack that @Magren had success with and now - knock on wood - it seems to be working even after several days and several restarts of HA!
Hi @Magren and @str2der
Does anyone have an idea how to mitigate this whilst using zwave-js? I searched my installation, but cannot seem to find a zwcfg.xml file. Any help is greatly appreciated!
One of my thermostats mounted outside the room being heated ended up picking the air sensor rendering it ā€œuselessā€
Oh no! I’m moving to zwave-js soon and I just expected this to work the same way! Then I’m also very interested in a solution for zwave-js!
Did you ever get this sorted out? I’m hesistating to switch to zwave-js now that i got all the readings from my z-trm2fx. Bought the newer z-trm3 to another room but i cannot control the settings on it at all.
It has been sorted out in zwavejs.
Oh sounds nice. Can you tell me how it works? Can you get the floor sensor temp, and adjust the temp etc.
I’m using z-trm2fx and the official zwave-js. So all features of the climate control component are working fine including current temperature, setting the target temperature and switching between predefined modes.
Are you using the floor sensor? Since there is no xml to tweak like the old z-wave integration.
Yes, the reading is from the floor sensor.
