Ok, this is driving me crazy…
This is an HAOS version 12.1 installed as a VP on ProxMox and I use this VM to test updates before doing them on my “production” VM.
I had to reboot ProxMox for a kernel update and both the prod and test HAOS vms would not get a DHCP ip. After much mucking around I did get the prod vm up but I really am not sure how as I’m trying the same on the test server and have not been able to get it to take either a static IP or DHCP IP. My network is a 10.0.0.0/24 network.
This is the console initial screen that shows the IPs
From there I enter network info…
Ok, I try to down the interface then enter a static IP and it says it completed successfully but it does not take the IP.
If I set the method back to auto then I get the default IP addr and not from my dhcp server, it should get 10.0.0.108, and I did check and it’s a static lease with the correct MAC from proxmox.
I had exactly the same issue with the prod haos server and after doing the above steps a couple times, “network update enp0s18 -e” then “network update enp0s18 --ipv4-address 10.0.0.108 --ipv4-gateway 10.0.0.1” it then got a dhcp lease as it also got the nameserver that I didn’t enter that time. I’ve tried that on the test server also and I can’t get the darn thing to take an IP or get a proper lease. I’m really not sure what’s going on here…
Here’s screen shots from Proxmox config showing the MAC and OPNsense showing the DHCP lease.
This seems like an HAOS bug to me???
Thanks in advance
