A previous install of HA in a friends house got corrupted, so I went to go and rebuild it for him…
Try as I might, on a fresh install of hass.io (v0.103.0) I first install Samba, then DuckDNS. All goes fine in the DuckDNS setup, it generates the keys etc. I update http in configuration.yaml with:
http:
base_url: https://[mydomain].duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
and when trying to access I get the error: “[mydomain].duckdns.org unexpectedly closed the connection”.
There are no errors in home-assistant.log
We had it running previously on the same port, so I’m pretty confident its not a router issue.
Any suggestions gratefully received.
