Hey, I have the Google assistant integration set up properly and I can sync devices exposed by the YAML config. However, I’d like to only expose entities that I’ve exposed through the Voice companion Exposed section which supposedly works for Nabu Casa. However, Google seems to be ignoring these entities and there’s no toggle for Google Assistant in the Exposed entities section. How can I make Google Assistant sync with the exposed entities defined in the UI?
Turns out the UI entities screen is only for Nabu Casa. I had to manually add a list of supported entities to the configuration.yml
