I was editing a new automation and testing it. After I got it working I decided to get rid of the commented lines and I tried to validate the configutation once more (that was working perfectly before). Then I noticed that the frontend was unable to call the check configuration and that I was getting an error. So I decided to restart my home assistant because I thought that it was just a hiccup. After that I was I unable to boot home assistant. Checked the logs and google a little bit about it, did almost everything that I read in other threads but I’m right now stuck, not knowing what to do to next. Any help would be appreciated.
When I’m running from the console the following
hassio homeassistant check
I get the following
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/src/homeassistant/homeassistant/scripts/check_config.py", line 209, in check
check_ha_config_file(hass))
File "uvloop/loop.pyx", line 1451, in uvloop.loop.Loop.run_until_complete
File "/usr/src/homeassistant/homeassistant/scripts/check_config.py", line 381, in check_ha_config_file
p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 381, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 204, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 284, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 630, in validate_sequence
cval = validate(index_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 249, in _exec
return func(path, v)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 811, in validate_callable
return schema(data)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 345, in service
if valid_entity_id(value):
File "/usr/src/homeassistant/homeassistant/core.py", line 89, in valid_entity_id
return ('.' in entity_id and
TypeError: argument of type 'NoneType' is not iterable
Fatal error while loading config: argument of type 'NoneType' is not iterable
Failed config
General Errors:
- argument of type 'NoneType' is not iterable
Successful config (partial)
