Unable to get letsencrypt certificate on Synology NAS
I am trying to setup letsencrypt on synology for SSL following the guide here
Currently at Installing TLS/SSL using Let's Encrypt - Community Guides - Home Assistant Community
Now what I have done on my router forwarded 80 and 443 to 8123 to my homeassistant IP
I am not using duckdns but another service. I am able to open the following combination which goes to my HA landing page
https://mydomain.com:8123 or https://mydomain.com doesn’t work atm
The commands seems a bit outdated on the page so I have done the following
docker run -it --rm -p 8080:80 --name certbot
-v “/etc/letsencrypt:/etc/letsencrypt”
-v “/var/lib/letsencrypt:/var/lib/letsencrypt”
certbot/certbot:latest certonly
–standalone --preferred-challenges http-01
–email [email protected] -d mydomain.com
It fails with the following
Failed authorization procedure. mydomain.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://mydomain.com/.well-known/acme-challenge/XXXXXXXXXXXXX [IP]: 404
the page doesn’t open
I couldnt find the .well-known directory and also I know my port forwarding and 8080 is totally screwed up as I have my mind twisted over it
What all do I have wrong here?
If you have the ability to add a txt record to your domain, look at DNS authentication instead of http
Doesn’t… if i can’t get above to work then will look at a different provider… but would prefer to stick to current one
Well now I am using duckdns for testing and after using dehydrater i get an error
2018-01-15 20:17:29 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_certificate’]. Got ‘/volume1/homeassistant/config/ssl/fullchain.pem’
not a file for dictionary value @ data[‘http’][‘ssl_key’]. Got ‘/volume1/homeassistant/config/ssl/privkey.pem’. (See /config/configuration.yaml, line 27). Please check the docs at HTTP - Home Assistant
HA runs as root in synology docker and tried different locations and all chmod / chown options I think
Your file location is likely to be
From within the docker
To do certbot http authentication you should not have 80 and 443 pointing to HA
This should point to hostserver/certbotfolder or something similar. Certbot should have read/write access to folder. What happens is certbotfolder places file on server via 80 then checks via 443 for file.
I use nginx in front of server and 80 and 443 go there.
I then use nginx config file to determine where incoming 80 and 443 requests go. When renew domains, config file temporary Change so all request for all I domain go to certbot…then change back after renew (10-20 second downtime). Not needed for you but just extra info. If you forward 80 and 443 to certbot read/writeable folder it will be enough
I tried that as well
2018-01-16 07:08:32 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_certificate’]. Got ‘/config/ssl/fullchain.pem’
not a file for dictionary value @ data[‘http’][‘ssl_key’]. Got ‘/config/ssl/privkey.pem’. (See /config/configuration.yaml, line 27). Please check the docs at HTTP - Home Assistant
2018-01-16 07:08:32 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
Thanks… I have gone DNS way instead for the ease…
Okay. What is your volume/mount section in your homeassistant docker config and what is the full path of the ssl cert/key?
Damn… got the cert working…
was a symlink issue… thanks guys :slight_smile:
