<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE properties SYSTEM 'http://java.sun.com/dtd/properties.dtd'>
<properties>
Loads default configuration for the Hass.io add-on.
WARNING: Do not remove this line!
<entry key='config.default'>/etc/traccar/hassio.xml</entry>
<entry key='database.driver'>com.mysql.jdbc.Driver</entry>
<entry key='database.url'>jdbc:mysql://core-mariadb:3306/traccar?serverTimezone=UTC&useSSL=false&allowMultiQueries=true&autoReconnect=true&useUnicode=yes&characterEncoding=UTF-8&sessionVariables=sql_mode=''</entry>
<entry key='database.user'>secret</entry>
<entry key='database.password'>secret</entry>
This is the main configuration file. All your configuration parameters should be placed in this file.
Parameters in the main config file override values in the default file. Do not
remove "config.default" parameter from this file unless you know what you are doing.
For list of available parameters see following page:
https://www.traccar.org/configuration-file/
<!-- Enter you custom configuration below this line -->
</properties>
Hi, I have the same problem.
Traccar server in Hassio shows that all devices are online but I simply don’t see anything in device tracker card or know_devices and even not in sensors.
If anybody could advice it would be helpful because traccar its for me very reliable solution.
hello, i just installed it right now…i open and redirect ports 8082 and 5055 in my public ip to my nuc ip where is running hassio
in configuration.yaml:
device_tracker:
- platform: traccar
host: 192.168.1.2 #my nuc ip
port: 8082
username: xxxx #your user
password: xxxx #your password
I have the same issue (Traccar app data not getting to Hassio Traccar server addon).
I am trying to use port 18682 and have it open through my router (like many ports) but still nothing.
Do I need to open it in Linux Ubuntu or does having it in the configuration.yaml do that?
I have hassio running on a I7 minipc with Ubuntu.
Add on config:
Device Identifier with username(traccar registered email address and password) entered as device in Traccar UI…
Status in IOS APP. Location update, Send failed.
Hello @Sawadee
You don’t need to open port 18682 but open the port on which your tracking device (phone/gps tracker transmits)
There are two steps
Linking your device to Traccar itself. This you should verify by logging into the Traccar server via the addon. If the device speaks to the Traccar server , it means your setup it correct
Making Traccar and Homeassistant speak to each other. This is where the entry into configuration.yaml comes in. For me it works with 127.0.0.1
I suspect that step 1 is not working for you. Could you check and report back.
Thank you.
Hi, thanks for the help. You are correct. I am unable to connect the client on the phone to the server (Traccar Addon in HA).
I should mention that I have tied the Webhook and it works partially. That is it sends a location to HA and creates a tracker device with the device ID from the Traccar iPhone app. So that gets through but of course not to the add on.
So used port 18682 because I saw it was recommended. What port should I use? 8082? I think I saw that is the default port.
PS
Tried port 8082 then with open in router, no luck.
Yes, webhooks is a bypass for the Traccar server and is only useful for the phone client. If you were to use Traccar with what is it intended for , i.e. a GPS tracker on your automobile, then you need to first add the tracking device to your Traccar server and then it will start communicating.
I do not use Traccar client on my phone (I use icloud3 custom component for presence detection).
But I do use a ST-901 GPS tracker in my car which reports its position and ignition status to HomeAssistant via Traccar server.
Well glad your setup works. I am still trying to get traccar addon to work. I know I am sending but it is not getting the data. Just don’t know what else to try. Have tried 127.0.0.1 with no luck. Tried different ports no luck. This addon just shouldn’t give people so much trouble. I assume I have to change something but don’t know what.
Thanks again…
I am running Hssio on an i7 computer on ubuntu 18.04 with the HA recommended docker install
This is the alternative install for Ubuntu.
(Installation - Home Assistant)
This is my configuration:
App on Iphone:
Identifier: mySixDIgitIdentifier
Server URL http://my.dyndns.server:8082 <-(this port is open on my Ubiquiti Edge router)
On HA Traccar Addon:
ACCOUNT
Email: myemail
Password: mypassword
Hass.io Add-on: Traccar
Modern GPS Tracking Platform
Add-on version: 0.6.1
You are running the latest version of this add-on.
System: Ubuntu 18.04.4 LTS (amd64 / qemux86-64)
Home Assistant version: 0.105.5
Supervisor version: 201
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
Log level is set to DEBUG
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[10:05:10] DEBUG: Requested API resource: http://hassio/dns/info
[10:05:10] DEBUG: Request method: GET
[10:05:10] DEBUG: Request data: {}
[10:05:10] DEBUG: API HTTP Response code: 200
[10:05:10] DEBUG: API Response: {“result”: “ok”, “data”: {“version”: “1”, “latest_version”: “1”, “host”: “172.30.32.3”, “servers”: , “locals”: [“dns://192.168.123.254”, “dns://4.2.2.2”]}}
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] traccar.sh: executing…
[cont-init.d] traccar.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[10:05:10] INFO: Starting Traccar server…
2020-02-18 10:05:11 INFO: HikariPool-1 - Starting…
2020-02-18 10:05:11 INFO: HikariPool-1 - Start completed.
2020-02-18 10:05:11 INFO: Clearing database change log checksums
2020-02-18 10:05:11 INFO: SELECT COUNT() FROM PUBLIC.DATABASECHANGELOGLOCK
2020-02-18 10:05:11 INFO: SELECT LOCKED FROM PUBLIC.DATABASECHANGELOGLOCK WHERE ID=1
2020-02-18 10:05:11 INFO: Successfully acquired change log lock
2020-02-18 10:05:12 INFO: SELECT MD5SUM FROM PUBLIC.DATABASECHANGELOG WHERE MD5SUM IS NOT NULL
2020-02-18 10:05:12 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = NULL
2020-02-18 10:05:12 INFO: Successfully released change log lock
2020-02-18 10:05:12 INFO: SELECT COUNT() FROM PUBLIC.DATABASECHANGELOGLOCK
2020-02-18 10:05:12 INFO: SELECT LOCKED FROM PUBLIC.DATABASECHANGELOGLOCK WHERE ID=1
2020-02-18 10:05:12 INFO: Successfully acquired change log lock
2020-02-18 10:05:12 INFO: Can not use class liquibase.parser.core.json.JsonChangeLogParser as a Liquibase service because org.yaml.snakeyaml.constructor.BaseConstructor is not in the classpath
2020-02-18 10:05:12 INFO: Can not use class liquibase.parser.core.yaml.YamlChangeLogParser as a Liquibase service because org.yaml.snakeyaml.constructor.BaseConstructor is not in the classpath
2020-02-18 10:05:13 INFO: SELECT MD5SUM FROM PUBLIC.DATABASECHANGELOG WHERE MD5SUM IS NOT NULL
2020-02-18 10:05:13 INFO: SELECT COUNT() FROM PUBLIC.DATABASECHANGELOG
2020-02-18 10:05:13 INFO: Reading from PUBLIC.DATABASECHANGELOG
2020-02-18 10:05:13 INFO: SELECT * FROM PUBLIC.DATABASECHANGELOG ORDER BY DATEEXECUTED ASC, ORDEREXECUTED ASC
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:d59fa93049c031a8bcfbc02958c1942c’ WHERE ID = ‘changelog-4.0-clean’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-4.0-clean’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:1adabae3238e02ccc97cc422359a58a0’ WHERE ID = ‘changelog-4.0-clean-common’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-4.0-clean’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:ea6f202534dc7845fd1a49e1d8384d9c’ WHERE ID = ‘changelog-3.3’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.3’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:194e3ae7ec6d201917136e04a26e237b’ WHERE ID = ‘changelog-3.5’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.5’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:1ec7941b03749f24e365bc6126b07e1a’ WHERE ID = ‘changelog-3.6’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.6’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:2e444e379f31d0b8e09273ec7ffe87a0’ WHERE ID = ‘changelog-3.7’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.7’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:974c33d2fb399ef6477c3897450fb078’ WHERE ID = ‘changelog-3.7-notmssql’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.7’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:74d68027951f8d2ae6bb2e24df8365bc’ WHERE ID = ‘changelog-3.8’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.8’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:34822842d65deb843a7d16f857d52ecc’ WHERE ID = ‘changelog-3.9’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.9’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:e1ddbe83e1ecf856a912755fc118f82e’ WHERE ID = ‘changelog-3.10’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.10’
2020-02-18 10:05:13 INFO: UPDATE PUBLIC.DATABASECHANGELOG SET MD5SUM = ‘8:191c21d8f0f921845cf93bbc9d0639b9’ WHERE ID = ‘changelog-3.10-notmssql’ AND AUTHOR = ‘author’ AND FILENAME = ‘changelog-3.10’
This keeps going 3.11 3.12 etc to 4.17 then this
2020-02-18 10:05:13 INFO: Successfully released change log lock
2020-02-18 10:05:13 INFO: Logging initialized @2315ms to org.eclipse.jetty.util.log.Slf4jLog
2020-02-18 10:05:14 INFO: Operating system name: Linux version: 5.3.0-28-generic architecture: amd64
2020-02-18 10:05:14 INFO: Java runtime name: OpenJDK 64-Bit Server VM vendor: IcedTea version: 25.232-b09
2020-02-18 10:05:14 INFO: Memory limit heap: 455mb non-heap: 0mb
2020-02-18 10:05:14 INFO: Character encoding: UTF-8 charset: UTF-8
2020-02-18 10:05:14 INFO: Version: 4.7
2020-02-18 10:05:14 INFO: Starting server…
2020-02-18 10:05:14 INFO: jetty-9.4.26.v20200117; built: 2020-01-17T12:35:33.676Z; git: 7b38981d25d14afb4a12ff1f2596756144edf695; jvm 1.8.0_232-b09
2020-02-18 10:05:14 INFO: Started o.t.w.@68ab6ab0{/,null,AVAILABLE}
2020-02-18 10:05:14 INFO: DefaultSessionIdManager workerName=node0
2020-02-18 10:05:14 INFO: No SessionScavenger set, using defaults
2020-02-18 10:05:14 INFO: node0 Scavenging every 600000ms
2020-02-18 10:05:14 INFO: Started o.e.j.s.ServletContextHandler@59f45950{/,null,AVAILABLE}
[10:05:14] INFO: Starting NGinx server…
2020-02-18 10:05:14 INFO: Started ServerConnector@aaee2a2{HTTP/1.1,[http/1.1]}{localhost:18682}
2020-02-18 10:05:14 INFO: Started @4039ms’
Using 127.0.0.1 and 18682 in configuration.yaml works for me as well.
But how can I also access that port from externally to have Android app traccar manager Access it?
