Unable to go to homeassistant.local: 8123 page after first installation (VM)
I installed a VM on my Unraid server to be able to use Home Assistant. My VM creation worked fine, I was able to launch the image and it settled down fine. According to the tutorials to be able to configure Home assistant (login and passwd), I must connect locally at the following address: http: //homeassistant.local: 8123. But impossible, I got an error message that the site does not exist.
I tried to find a solution to my problem but couldn’t. I have no errors in my logs etc …
Thank you for your help !,
Hello I have the same issue did you find a solution?
Thank you bye
Exactly the same. Instaled VM on Windows. The Supervisor ends fine but It has been imposible access to Home Assistant, introducing in Chrome the address http://homeassistant.local:8123.
It returns page not found. Same if you put the router IP address instead “.local”.
No other errors found, so there are no clues to go ahead.
Please I am very new and would be very grateful for some help to get start.
Thank you beforehand.
Same problem Installed VM on windows and no acces to http://homeassistant.local:8123, I removed firewall protection and protections in browsers Edge and Chrome but still no acces, if you already solve the problem please let me know.
Thanks in advanced!!!
Hi the problems was solved.
when it is used VM previous start up it is mandatory that the network conection must be enable as a bridge after that the http://homeassistant.local:8123 will be conected.
Have a nice day!!!
