Unable to identify location of error in code
Following a recent esphome update, I noticed the following error…
[W][homeassistant.binary_sensor:017]: Can't convert 'unknown' to binary state!
I have attempted to locate the cause, but no matter what I change it doesn’t appear to affect the error?
Here’s my code…
esp8266:
 board: nodemcuv2
 framework:
  version: recommended
esphome:
  on_boot:
    - lambda: 'id(climate_id).mode = climate::CLIMATE_MODE_COOL;'
# Enable logging
logger:
# Enable Home Assistant API
api:
  reboot_timeout: 0s
ota:
  password: !secret ota_password
wifi:
#  use_address: testbuild.local
  ssid: !secret wifi_ssid
  ap:
    ssid: "esp1_studio Fallback Hotspot"
    password: "Redacted"
captive_portal:
# MQTT Interface
mqtt:
  broker: !secret mqtt_broker
  port: 1883
  reboot_timeout: 0s
  keepalive: 60s
  discovery: false
  on_message:
    - topic: HomeAssistant/Studio/Aircon/Status
      payload: "OFF"
      qos: 0
      then:
        - binary_sensor.template.publish:
            state: off
        - logger.log: "The AC is OFF"
      payload: "ON"
      qos: 0
      then:
            state: on
        - logger.log: "The AC is ON"
status_led:
  pin: GPIO2
# Studio door reed switch sensor.
binary_sensor:
# AC status
    on_press:
          state: off
    on_release:
          state: on
    on_press:
      - climate.control:
          mode: 'cool'
      - switch.turn_on: damper_sw
    on_release:
      - climate.control:
          mode: 'off'
      - switch.turn_off: damper_sw
# Studio Air Conditioner Status from HA
  - platform: homeassistant
    name: "Studio AC Status from HA"
    entity_id: binary_sensor.studio_ac_climate
#Temperature Sensor Pin
dallas:
  - pin: D1
    update_interval: 30s
#Relay switches
switch:
  - platform: gpio
    pin:
      number: D6
      inverted: True
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: gpio
    pin:
      number: D5
      inverted: True
  - platform: gpio
    pin:
      number: D7
      inverted: True
# Restart
  - platform: restart
    name: "esp1 Studio Restart"
# Studio Outside DHT11 Sensor
  - platform: dht
    model: DHT11
    pin: D2
    temperature:
      name: "Studio DHT Out Temp"
    humidity:
      name: "Studio DHT Humidity"
# Studio Inside temperature sensor
  - platform: dallas
    resolution: 12
    address: 0x1101143025227D28
# Studio Outside temperature sensor
#  - platform: dallas
#    id: out_dallas_id
#    resolution: 12
#    address: 0xE602131B13F9AA28
#    name: studio_out_temp
    on_value:
      then:
      - if:
          condition:
            and:
              # Is the outside temp below 19 and the AC off
              - binary_sensor.is_off: studio_ac_climate
              - lambda: 'return id(studio_dht_out_temp).state < 19;'
          then:
              # Open the damper
                  state: on
              - mqtt.publish:
                  topic: HomeAssistant/Studio/Damper/Status
                  payload: "1"
              - logger.log: "The damper and climate is active"
      - if:
          condition:
            or:
              # Is the outside temp above 19 or the AC on
              - binary_sensor.is_on: ac_status
              - lambda: 'return id(studio_dht_out_temp).state > 19;'
          then:
                  state: off
              - mqtt.publish:
                  payload: "0"
              - logger.log: "The damper and climate is off"
climate:
  - platform: thermostat
    min_idle_time: 30s
    min_cooling_off_time: 120s
    min_cooling_run_time: 120s
    name: "Studio Climate Controller"
    sensor: in_dallas_id
    default_target_temperature_high: 22 °C
    cool_action:
      - switch.turn_on: fan_sw
      - logger.log: "The fan is now on"
      - mqtt.publish:
          topic: HomeAssistant/Studio/Fan/Status
          payload: "1"
    idle_action:
      - switch.turn_off: fan_sw
      - logger.log: "The fan is now off"
      - mqtt.publish:
          payload: "0"
Please forgive my rubbish coding… it has been working successfully for quite some time now.
Any suggestions greatly appreciated.
This must be the binary sensor causing the warning, are you using the correct entity_id and if so, check the value with the developers tools in HA.
The unknown state I’d usually occuring during boots, so you do not get the error once HA is running and searching for the big at that point is useless.
Yes, the error appears to only appear at boot time, and the device appears to operate as expected. So I am not sure why it all of a sudden started happening.
@jsuanet I will monitor the situation, and perhaps some of the later updates requires a change to some syntax or the like?
Unless you need a feature of the update then I would advice against updating.
ESP-Home nodes are local and live their lives with very few tasks, they don’t need to be bothered with updates.
Most of my ESP-Home devices have years old code and because of that I don’t have any problems.
It is the HA standard, so maybe your device integration is just being aligned with that.
Have you checked the breaking changes notices
