Unable to import states from other entities
So i’ve spent so much time on this, and now i’m trying to dumb it down as much as possible, but i’m just not able to interact with the StateMachine. It seems no matter what i try, i get
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 281, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/accounts/sensor.py", line 18, in setup_platform
    add_entities([AccountsSensor(hass, entity_id)], False)
  File "/config/custom_components/accounts/sensor.py", line 28, in __init__
    self._stat = hass.states.get(self._entity_id).state
AttributeError: 'NoneType' object has no attribute 'state'
This is my current code:
import logging
import async_timeout
# from homeassistant.helpers.aiohttp_client import async_get_clientsession
from homeassistant.helpers.entity import Entity
_LOGGER = logging.getLogger(__name__)
DOMAIN = 'accounts'
ENTITY_ID = 'sun.sun'
def setup_platform(hass, config, add_entities, discovery_info=None):
    entity_id = ENTITY_ID
    _LOGGER.info('Setup complete')
class AccountsSensor(Entity):
    def __init__(self, hass, entity_id):
        self._name = 'testname'
        self._entity_id = entity_id
    @property
    def name(self):
        return self._name
    @property
    def state(self):
        return self._state
Is there something that I’m not importing, or something i’m skipping?
So I found the reason and a nasty solution:
import logging
DOMAIN = 'accounts'
ENTITY_ID = 'input_text.test'
    temp = False
    while temp is False:
       if hass.states.get(ENTITY_ID):
           _LOGGER.error("Yes")
           state = hass.states.get(ENTITY_ID).state
           _LOGGER.error(state)
           temp = True
       else:
           _LOGGER.error("No")
    add_entities([AccountsSensor(state)], True)
    def __init__(self, state):
        self._name = 'test'
        self._state = state
    @property
    def name(self):
        return self._name
    @property
    def state(self):
        return self._state
How do handle these delays properly?
