When trying to add an integration for Apple TV, I get an Error: Config flow could not be loaded
Going to logs, there’s this error:
Logger: homeassistant.util.package
Source: util/package.py:99
First occurred: 19:08:59 (3 occurrences)
Last logged: 22:46:31
Unable to install package pyatv==0.8.2: ERROR: Cannot install pyatv because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/user_guide/#fixing-conflicting-dependencies
When I try to install pyatv from the console, I see problems with these dependencies: bitarray and miniaudio.
ERROR: Command errored out with exit status 1:
command: /volume1/@appstore/homeassistant/env/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/setup.py'"'"'; __file__='"'"'/tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-sprt80vw
cwd: /tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/
Complete output (23 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.8
creating build/lib.linux-x86_64-3.8/bitarray
copying bitarray/util.py -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/test_util.py -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/test_bitarray.py -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/__init__.py -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/pythoncapi_compat.h -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/bitarray.h -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/test_data.pickle -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/py.typed -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/util.pyi -> build/lib.linux-x86_64-3.8/bitarray
copying bitarray/__init__.pyi -> build/lib.linux-x86_64-3.8/bitarray
running build_ext
building 'bitarray._bitarray' extension
creating build/temp.linux-x86_64-3.8
creating build/temp.linux-x86_64-3.8/bitarray
/github/workspace/toolchain/syno-x64-7.0/work/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -I/github/workspace/toolchain/syno-x64-7.0/work/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/include -I/github/workspace/spk/python38/work-x64-7.0/install//var/packages/python38/target/include -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -L /github/workspace/spk/python38/work-x64-7.0/install/var/packages/python38/target/lib -I /github/workspace/spk/python38/work-x64-7.0/install/var/packages/python38/target/include -I/github/workspace/toolchain/syno-x64-7.0/work/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/include -I/github/workspace/spk/python38/work-x64-7.0/install//var/packages/python38/target/include -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -L /github/workspace/spk/python38/work-x64-7.0/install/var/packages/python38/target/lib -I /github/workspace/spk/python38/work-x64-7.0/install/var/packages/python38/target/include -fPIC -I/volume1/@appstore/homeassistant/env/include -I/var/packages/python38/target/include/python3.8 -c bitarray/_bitarray.c -o build/temp.linux-x86_64-3.8/bitarray/_bitarray.o
unable to execute '/github/workspace/toolchain/syno-x64-7.0/work/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-gcc': No such file or directory
error: command '/github/workspace/toolchain/syno-x64-7.0/work/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-gcc' failed with exit status 1
ERROR: Failed building wheel for bitarray
Running setup.py clean for bitarray
Failed to build bitarray
Installing collected packages: bitarray
Running setup.py install for bitarray ... error
command: /volume1/@appstore/homeassistant/env/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/setup.py'"'"'; __file__='"'"'/tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-3qttxp5l/install-record.txt --single-version-externally-managed --compile --install-headers /volume1/@appstore/homeassistant/env/include/site/python3.8/bitarray
running install
running build
running build_py
creating build
running build_ext
ERROR: Command errored out with exit status 1: /volume1/@appstore/homeassistant/env/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/setup.py'"'"'; __file__='"'"'/tmp/pip-install-34iv6akc/bitarray_707b7d8510a8432994c3aefcf39d3739/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-3qttxp5l/install-record.txt --single-version-externally-managed --compile --install-headers /volume1/@appstore/homeassistant/env/include/site/python3.8/bitarray Check the logs for full command output.
Spent couple of hours on this and seems that I can’t find a solution for this.
