Hi I am running latest version of HA on RPi3. and recently got orvibo plugs, the outlet works fine from app but after adding to configuration.yaml file the log says could not install dependency. I tried manually installing via pip command venv is active but ended up with following error
Collecting orvibo
Using cached orvibo-1.1.1.tar.gz
Complete output from command python setup.py egg_info:
File “”, line 1, in
File “/tmp/pip-build-81jzcs_c/orvibo/setup.py”, line 16, in
‘Programming Language :: Python :: 3’,
File “/usr/lib/python3.4/distutils/core.py”, line 134, in setup
ok = dist.parse_command_line()
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/setuptools/dist.py”, line 347, in parse_command_line
result = _Distribution.parse_command_line(self)
File “/usr/lib/python3.4/distutils/dist.py”, line 471, in parse_command_line
args = self._parse_command_opts(parser, args)
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/setuptools/dist.py”, line 658, in _parse_command_opts
nargs = _Distribution._parse_command_opts(self, parser, args)
File “/usr/lib/python3.4/distutils/dist.py”, line 527, in _parse_command_opts
cmd_class = self.get_command_class(command)
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/setuptools/dist.py”, line 479, in get_command_class
self.cmdclass[command] = cmdclass = ep.load()
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pkg_resources/init.py”, line 2291, in load
return self.resolve()
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pkg_resources/init.py”, line 2297, in resolve
module = import(self.module_name, fromlist=[‘name’], level=0)
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/setuptools/command/init.py”, line 11, in
from setuptools.command import install_scripts
File “”, line 2237, in _find_and_load
File “”, line 2226, in _find_and_load_unlocked
File “”, line 1200, in _load_unlocked
File “”, line 1129, in _exec
File “”, line 1467, in exec_module
File “”, line 1570, in get_code
File “”, line 656, in _compile_bytecode
ValueError: bad marshal data (unknown type code)
Please help. Thank you
