When installing HA using VMM on Sinology, the installation fails with “[supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server”.
It installs fine from docker but not from vmm.
Is there a workaround for this?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
INFO: Starting local supervisor watchdog…
s6-rc: info: service legacy-services successfully started
[main] Initializing Supervisor setup
[supervisor.docker.network] Can’t find Supervisor network, creating a new network
[supervisor.bootstrap] Seting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor Package amd64-hassio-supervisor · GitHub with version 2023.11.6
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[main] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Found Package amd64-hassio-cli · GitHub versions:
[supervisor.docker.interface] Attaching to Package amd64-hassio-cli · GitHub with version 2023.10.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI Package amd64-hassio-cli · GitHub with version 2023.10.0 - 172.30.32.5
[supervisor.docker.interface] Found Package amd64-hassio-dns · GitHub versions:
[supervisor.docker.interface] Attaching to Package amd64-hassio-dns · GitHub with version 2023.06.2
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS Package amd64-hassio-dns · GitHub with version 2023.06.2 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found Package amd64-hassio-audio · GitHub versions:
[supervisor.docker.interface] Attaching to Package amd64-hassio-audio · GitHub with version 2023.10.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio Package amd64-hassio-audio · GitHub with version 2023.10.0 - 172.30.32.4
[supervisor.docker.interface] Found Package amd64-hassio-observer · GitHub versions:
[supervisor.docker.interface] Attaching to Package amd64-hassio-observer · GitHub with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer Package amd64-hassio-observer · GitHub with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found Package amd64-hassio-multicast · GitHub versions:
[supervisor.docker.interface] Attaching to Package amd64-hassio-multicast · GitHub with version 2023.06.2
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast Package amd64-hassio-multicast · GitHub with version 2023.06.2 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for Package qemux86-64-homeassistant · GitHub
[supervisor.homeassistant.core] No Home Assistant Docker image Package qemux86-64-homeassistant · GitHub found.
[supervisor.docker.interface] Attaching to Package qemux86-64-homeassistant · GitHub with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant Package qemux86-64-homeassistant · GitHub with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 11.2 / BootSlot A
[supervisor.store.git] Cloning add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
[supervisor.store.git] Cloning add-on GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on repository
[supervisor.store.git] Cloning add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
[supervisor.store] Loading add-ons from store: 71 all - 71 new - 0 remove
[supervisor.addons] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - setup
[main] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.addons] Phase ‘initialize’ starting 0 add-ons
[supervisor.addons] Phase ‘system’ starting 0 add-ons
[supervisor.addons] Phase ‘services’ starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons] Phase ‘application’ starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image Package qemux86-64-homeassistant · GitHub to Package qemux86-64-homeassistant · GitHub
[supervisor.docker.interface] Downloading docker image Package qemux86-64-homeassistant · GitHub with tag 2023.12.0.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
I have the same Problem on a Raspberry Pi 3 with the HA OS Image
Ok, seems it needed a really long time - next morning the Home Assistant is up and running.
