I’m trying to install using the interface in home assistant but I’m getting the typical can’t connect error
I’ve had it before, but managed to overcome it, but this time I’ve tried all my old tricks and failing
It’s plausible I’ve had WLED on the device before, but it’s not being picked up on my WiFi so maybe not
I don’t have a boot button, only a reset and holding that doesn’t seem to do anything
I know I’m using the right com port and have tried different usb slots
Might I be missing something, any other way I can install?
Thanks - at least I get some visual feedback there Serial port WebSerial VendorID 0x1a86 ProductID 0x7523 Connecting...Error: Failed to execute 'open' on 'SerialPort': Failed to open serial port.
And now it’s working (in https://web.esphome.io/ NOT in Home Assistant … seems somewhere between me last doing it and now either drivers corrupted or windows stopped liking them
Although after flashing I now get An error occurred. Improv Wi-Fi Serial not detected
EDIT: Resetting the device and configure wifi allowed me to enter credentials (wouldn’t work prior to reset), but now it just timeout
EDIT2: Only way i could actually get it past that timeout was to code the sensor, export and manually install through the link above. Seems to be up and running now tho
