I did a bit more reading and found the ESPHome Flasher method to flash the board.
I downloaded the “ESPHome-Flasher-1.1.0-windows-x64.exe” and tried to install it. But I get the message
“This app can’t run on you PC…”.
My guess is, that’s because i’m running a 32bit Win 10 OS and the set up file is 64bit. If that’s true, is there a 32bit setup file? If not then what can I do to flash my D1 mini?
Hey, today i received my D1 Mini but i cant find info on esphome.io about this board to flash it.
Can anyone share his settings?
I will connect a DHT22 sensor but i see D1,D2,D3 pins and not GPIO as in the generic ESP8266 guide.
