Unable to install HACS
Hi
A newbie here. I just install Home Assistant from a virtual disk image and running VM Virtualbox on a Win 10. I can setup Samba Share, ESP Home, File Editor and other AddOns. My next job was to install HACS, but I have problem even getting to see the API screen. So any help will be appreciated.
I have follows all the instruction, even clearing my browser cache, and when I get to Configuration, Integration, click on the bottom right + sign, type in HACS and click on HACS icon, I noticed that something was load on the back and then gone away. The next time I click on the icon, it just say “Please wait while the integration is being install.” and it stays there forever.
Looking at the log, it listed as follows:
2020-11-29 00:34:45 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py”, line 422, in _handle_request
resp = await self._request_handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py”, line 499, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py”, line 118, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 18, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 72, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 136, in post
return await super().post(request)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 69, in post
result = await self._flow_mgr.async_init(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 119, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 532, in async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 343, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 74, in async_get_integration_with_requirements
await async_process_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 121, in async_process_requirements
if pkg_util.is_installed(req):
File “/usr/src/homeassistant/homeassistant/util/package.py”, line 54, in is_installed
return version(req.project_name) in req
File “/usr/local/lib/python3.8/site-packages/pkg_resources/init.py”, line 3125, in contains
return self.specifier.contains(item, prereleases=True)
File “/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/specifiers.py”, line 789, in contains
item = parse(item)
File “/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py”, line 56, in parse
return Version(version)
File “/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py”, line 275, in init
match = self._regex.search(version)
TypeError: expected string or bytes-like object
Regards
Peter
Hi. Same problem here. I use HassOS 5.6 with HA 0.118.4. After trying to install HACS via integrations I got an infinite setup process with the following message in the log. If I try to use .yaml setup I’ve got infinite configuration check and system/os restart didn’t help.
`Logger: aiohttp.server
Source: util/package.py:54
First occurred: 12:19:30 AM (1 occurrences)
Last logged: 12:19:30 AM
Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 136, in post
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 69, in post
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 119, in async_init
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 532, in async_create_flow
  File "/usr/src/homeassistant/homeassistant/setup.py", line 343, in async_process_deps_reqs
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 74, in async_get_integration_with_requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 121, in async_process_requirements
  File "/usr/src/homeassistant/homeassistant/util/package.py", line 54, in is_installed
  File "/usr/local/lib/python3.8/site-packages/pkg_resources/__init__.py", line 3125, in __contains__
  File "/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 789, in contains
    item = parse(item)
  File "/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py", line 56, in parse
  File "/usr/local/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py", line 275, in __init__
TypeError: expected string or bytes-like object`
