I have tried flashing it from windows and from ubuntu system.
the installation is stuck at the " Preparing Home Assistant". if I click the blue button I see the following:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[16:07:32] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[16:07:32] INFO: Starting local supervisor watchdog...
21-02-19 16:07:34 INFO (MainThread) [__main__] Initializing Supervisor setup
21-02-19 16:07:34 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-02-19 16:07:34 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4
21-02-19 16:07:34 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armv7-hassio-supervisor with version 2021.02.11
21-02-19 16:07:34 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
21-02-19 16:07:34 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['homeassistant/armv7-hassio-supervisor:2021.01.7']
21-02-19 16:07:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-02-19 16:07:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-19 16:07:36 INFO (MainThread) [__main__] Setting up Supervisor
21-02-19 16:07:36 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-02-19 16:07:36 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-02-19 16:07:37 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-19 16:07:37 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-19 16:07:37 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-19 16:07:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-02-19 16:07:40 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-19 16:07:40 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
21-02-19 16:07:40 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-02-19 16:07:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-dns with version 2021.01.0
21-02-19 16:07:40 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-02-19 16:07:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-audio with version 2021.02.1
21-02-19 16:07:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-cli with version 2021.02.1
21-02-19 16:07:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-observer with version 2020.10.1
21-02-19 16:07:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-multicast with version 3
21-02-19 16:07:40 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-19 16:07:40 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-02-19 16:07:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi4-homeassistant with version landingpage
21-02-19 16:07:40 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-02-19 16:07:40 INFO (MainThread) [supervisor.hassos] Detect HassOS 5.11 / BootSlot A
21-02-19 16:07:40 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of ESPHome
21-02-19 16:07:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-02-19 16:07:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-02-19 16:07:41 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of ESPHome
21-02-19 16:07:41 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
21-02-19 16:07:41 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-02-19 16:07:41 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-02-19 16:07:41 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-02-19 16:07:41 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-02-19 16:07:41 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-02-19 16:07:41 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-19 16:07:41 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-02-19 16:07:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-19 16:07:41 INFO (MainThread) [__main__] Running Supervisor
21-02-19 16:07:41 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-02-19 16:07:41 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-02-19 16:07:41 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-02-19 16:07:41 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
21-02-19 16:07:41 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
21-02-19 16:07:41 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
21-02-19 16:07:41 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-02-19 16:07:41 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-02-19 16:07:41 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-02-19 16:07:41 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-19 16:07:41 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-19 16:07:41 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-19 16:07:41 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-02-19 16:07:41 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-02-19 16:07:41 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-19 16:07:41 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-19 16:07:43 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-19 16:12:35 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-homeassistant:2021.2.3").
21-02-19 16:12:35 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 16:13:05 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-19 16:13:05 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-19 16:18:01 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-homeassistant:2021.2.3").
21-02-19 16:18:01 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 16:18:32 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-19 16:18:32 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-19 16:23:34 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-homeassistant:2021.2.3").
21-02-19 16:23:34 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 16:24:04 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-19 16:24:04 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
I would try to download and install the 64 bits version… not the 32 bits as showed… Maybe not the reason for the issue but for a Raspberry pi 4B, I would recommend it
thanks for the reply,
I have tried to install the 64bit version as well. stuck on the same screen. this is the log:
[fix-attrs.d] done.
[17:29:15] INFO: Using udev information from host
[cont-init.d] done.
[services.d] done.
[17:29:15] INFO: Starting local supervisor watchdog...
21-02-19 17:29:17 INFO (MainThread) [__main__] Initializing Supervisor setup
21-02-19 17:29:17 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-02-19 17:29:17 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
21-02-19 17:29:17 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/aarch64-hassio-supervisor with version 2021.02.11
21-02-19 17:29:17 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
21-02-19 17:29:17 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['homeassistant/aarch64-hassio-supervisor:2021.01.7']
21-02-19 17:29:19 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-02-19 17:29:19 ERROR (SyncWorker_0) [supervisor.resolution.evaluations.container] Corrupt docker overlayfs detect: 500 Server Error for http+docker://localhost/v1.40/images/sha256:0224debe9b363645c293064b5f3ca1049e9bcb7fcc339234dde9810d8c76543e/json: Internal Server Error ("readlink /mnt/data/docker/overlay2: invalid argument")
21-02-19 17:29:19 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-19 17:29:19 INFO (MainThread) [__main__] Setting up Supervisor
21-02-19 17:29:19 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-02-19 17:29:19 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-02-19 17:29:19 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-19 17:29:20 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-19 17:29:20 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-19 17:29:21 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-02-19 17:29:22 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-19 17:29:22 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
21-02-19 17:29:22 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-02-19 17:29:22 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-dns with version 2020.12.0
21-02-19 17:29:22 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-02-19 17:29:22 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-audio with version 2021.02.1
21-02-19 17:29:22 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-cli with version 2021.02.1
21-02-19 17:29:22 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-observer with version 2020.10.1
21-02-19 17:29:22 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-multicast with version 3
21-02-19 17:29:22 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-19 17:29:22 INFO (MainThread) [supervisor.plugins] dns does not have the latest version 2021.01.0, updating
21-02-19 17:29:22 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/aarch64-hassio-dns:2020.12.0 to homeassistant/aarch64-hassio-dns:2021.01.0
21-02-19 17:29:22 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-hassio-dns with tag 2021.01.0.
21-02-19 17:29:24 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/aarch64-hassio-dns:2021.01.0 -> 500 Server Error for http+docker://localhost/v1.40/images/homeassistant/aarch64-hassio-dns:2021.01.0/json: Internal Server Error ("readlink /mnt/data/docker/overlay2: invalid argument").
21-02-19 17:29:24 ERROR (MainThread) [supervisor.plugins.dns] CoreDNS update failed
21-02-19 17:29:24 ERROR (MainThread) [supervisor.plugins] Can't update dns to 2021.01.0, the Supervisor healthy could be compromised!
21-02-19 17:29:24 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-02-19 17:29:24 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi4-64-homeassistant with version landingpage
21-02-19 17:29:24 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-02-19 17:29:24 INFO (MainThread) [supervisor.hassos] Detect HassOS 5.11 / BootSlot A
21-02-19 17:29:24 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
21-02-19 17:29:24 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
21-02-19 17:29:28 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'auto_uart' is deprecated, use 'uart'. Please report this to the maintainer of ESPHome
21-02-19 17:29:28 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
21-02-19 17:29:28 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-02-19 17:29:28 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-02-19 17:29:28 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-02-19 17:29:28 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-02-19 17:29:28 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-02-19 17:29:28 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-19 17:29:28 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
21-02-19 17:29:28 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-02-19 17:29:28 ERROR (SyncWorker_0) [supervisor.resolution.evaluations.container] Corrupt docker overlayfs detect: 500 Server Error for http+docker://localhost/v1.40/images/sha256:0224debe9b363645c293064b5f3ca1049e9bcb7fcc339234dde9810d8c76543e/json: Internal Server Error ("readlink /mnt/data/docker/overlay2: invalid argument")
21-02-19 17:29:28 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-19 17:29:28 INFO (MainThread) [__main__] Running Supervisor
21-02-19 17:29:28 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-02-19 17:29:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-02-19 17:29:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-02-19 17:29:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
21-02-19 17:29:28 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
21-02-19 17:29:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
21-02-19 17:29:28 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-02-19 17:29:28 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-02-19 17:29:28 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-02-19 17:29:28 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-19 17:29:28 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 17:29:28 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 17:29:28 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-02-19 17:29:28 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-02-19 17:29:28 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-19 17:29:28 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-19 17:29:30 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-19 17:33:47 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 17:33:47 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 17:34:17 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 17:34:17 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 17:39:01 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 17:39:01 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 17:39:31 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 17:39:31 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 17:44:07 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 17:44:07 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 17:44:37 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 17:44:37 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 17:50:12 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 17:50:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 17:50:42 INFO (SyncWorker_7) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 17:50:42 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 17:55:46 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 17:55:46 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 17:56:16 INFO (SyncWorker_6) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 17:56:16 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:00:37 ERROR (SyncWorker_6) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:00:37 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:01:07 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:01:07 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:06:08 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:06:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:06:38 INFO (SyncWorker_7) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:06:38 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:11:27 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:11:27 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:11:58 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:11:58 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:17:08 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:17:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:17:38 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:17:38 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:21:47 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:21:47 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:22:17 INFO (SyncWorker_6) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:22:17 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:26:42 ERROR (SyncWorker_6) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:26:42 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:27:12 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:27:12 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:29:28 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-02-19 18:29:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-19 18:29:31 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
21-02-19 18:32:11 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:32:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:32:41 INFO (SyncWorker_7) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:32:41 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:37:11 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:37:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:37:41 INFO (SyncWorker_6) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:37:41 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:42:25 ERROR (SyncWorker_6) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:42:25 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:42:55 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:42:55 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:48:03 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:48:03 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:48:33 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:48:33 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:53:11 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:53:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:53:41 INFO (SyncWorker_7) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:53:41 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 18:58:33 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 18:58:33 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 18:59:03 INFO (SyncWorker_6) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 18:59:03 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 19:04:09 ERROR (SyncWorker_6) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 19:04:09 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 19:04:39 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 19:04:39 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
21-02-19 19:08:55 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.3 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.2.3/json: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3: No such image: homeassistant/raspberrypi4-64-homeassistant:2021.2.3").
21-02-19 19:08:55 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-19 19:09:25 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.3
21-02-19 19:09:25 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.3.
I have a similar issue. It is occurring on RPI4. The supervisor will not update because the system is reporting that it is unhealthy. Attempts to update do not work. I have tried several times with similar results. Error message is: No such image: homeassistant/aarch64-hassio-supervisor:2021.02.11 in the 64bit version.
Retried the image https://github.com/home-assistant/operating-system/releases/download/5.11/hassos_rpi4-64-5.11.img.xz
I have checked the DNS settings and restarted several times. Did log into root directory on ha client line and updated audio as there were a range of posts about that. When logged into command line, it is also not possible to update supervisor.
log details when connected:
21-02-22 06:44:32 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-02-22 06:44:32 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-02-22 06:44:32 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-02-22 06:44:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-02-22 06:44:32 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-22 06:44:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-02-22 06:44:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-22 06:44:33 INFO (MainThread) [__main__] Running Supervisor
21-02-22 06:44:33 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
21-02-22 06:44:33 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2021.02.11
21-02-22 06:44:33 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-hassio-supervisor with tag 2021.02.11.
21-02-22 06:45:06 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/aarch64-hassio-supervisor:2021.02.11 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/aarch64-hassio-supervisor:2021.02.11/json: Not Found ("no such image: homeassistant/aarch64-hassio-supervisor:2021.02.11: No such image: homeassistant/aarch64-hassio-supervisor:2021.02.11").
21-02-22 06:45:06 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed!
21-02-22 06:45:06 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future version of Home Assistant!
21-02-22 06:45:06 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-02-22 06:45:06 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-02-22 06:45:06 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
21-02-22 06:45:06 INFO (MainThread) [supervisor.core] Start Home Assistant Core
21-02-22 06:45:06 INFO (SyncWorker_1) [supervisor.docker.interface] Starting homeassistant
21-02-22 06:45:06 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-02-22 06:45:23 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-02-22 06:45:44 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-02-22 06:45:44 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
21-02-22 06:45:44 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-02-22 06:45:44 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
21-02-22 06:45:44 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-02-22 06:45:44 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-22 06:45:44 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/beta.json
21-02-22 06:45:44 WARNING (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
21-02-22 06:45:44 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-22 06:45:44 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-22 06:45:46 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-02-22 06:45:46 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-22 06:46:35 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2021.02.11
21-02-22 06:46:35 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-hassio-supervisor with tag 2021.02.11.
21-02-22 06:47:08 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/aarch64-hassio-supervisor:2021.02.11 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/aarch64-hassio-supervisor:2021.02.11/json: Not Found ("no such image: homeassistant/aarch64-hassio-supervisor:2021.02.11: No such image: homeassistant/aarch64-hassio-supervisor:2021.02.11").
21-02-22 06:47:08 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed!
When in command line, the following error notice appears:
udevd[205]: bind failed: address in use
udevd[205]: error binding udev control socket
overlayfs: overlapping upperdir path ```
Sorted out the issue on my machine with a complete new install. It was the only way that I found to get the updates working properly. The 505 error on the update error indicated issues with network settings but the RPI4 did ping addresses but would not update. Just had to bite the bullet for a reinstall and all items working again. I had also tried auto config of IP addresses via DHCP and fixed IP but no resolution without new install. Was having trouble when system was OS 5.11 but new image is OS 5.12
