No matter which method I use, I cannot get past the heartbeat during the install process. This is what screen shows:
[ K ] Started nput Event Daemon.
[ 7.135095] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 7.141744] rtc rtc0: Power loss detected, invalid time
[ 7.150230] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 7.151096] rtc-pcf85063 6-0051: registered as rtc0
[ 7.164961] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 7.166447] rtc rtc0: Power loss detected, invalid time
[ 7.141509] input-event-daemon[204]: i[ 7.179999] rtc-pcf85063 6-0051: hctosys: unable to read the hardware clock
nput-event-daemon: Start listening on 1 devices.[ 7.191495] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 7.192475] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 7.201942] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.217286] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.218291] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.224972] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.231917] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 7.238977] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ K ] Started 7.254226] usb 1-1: Product: USB 2.0 Hub [MTT]
;39mSerial Getty on ttyAMA2.[ 7.262455] hub 1-1:1.0: USB hub found
[ 7.268262] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.268299] hub 1-1:1.0: 4 ports detected
[ 7.279683] Registered R keymap rc-cec
[ 7.283947] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ K ] Reached target 7.295287] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
39mLogin Prompts.
[ K ] Reached target Multi-User System.
[ 7.324906] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.336550] Registered R keymap rc-cec
[ 7.356780] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.363775] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input4
[ 7.387721] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ K ] Reached targe[ 7.394702] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
t Sound Card.
[ 7.407068] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.415226] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.422711] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.432599] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.440055] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.450664] [drm] nitialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.492509] Console: switching to colour frame buffer device 80x30
[ 7.518675] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 7.753417] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 9.592192] random: crng init done
[ 9.595614] random: 7 urandom warning(s) missed due to ratelimiting
[ K ] Started Network Name Resolution.
[ K ] Reached target Network.
[ K ] Reached target Host and Network Name Lookups.
Welcome to Buildroot
yellow-installer login: [ 35.808202] cam-dummy-reg: disabling
worth noting also, the device never gets an IP and barely registers a POE draw about 2W from the switch. (it’s a 24port PoE unit from Ubiquiti - with PoE+ support, not sure if that makes a difference.)
To be clear, I have tried Option 1 and Option 2 in the official documentation, I have also tried with usboot imaging directly onto both eMMC and an NvME drive, the result is always the same the yellow light never changes from the heartbeat. At this point I am lost and considering cutting my losses, but if anyone has any ideas I’ll give it one more shot.
Thanks.
