I have a raspberry pi where i have installed home assistant as a OS. On the ha i have installed node-red and am trying to it with my zigbee devices. However when every i try to install: node-red-contrib-zigbee
i keep on getting this error:
2023-10-31T18:37:40.695Z Install : node-red-contrib-zigbee 0.21.0
2023-10-31T18:37:41.840Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2023-10-31T18:37:43.180Z [err] npm
2023-10-31T18:37:43.183Z [err] WARN config
2023-10-31T18:37:43.183Z [err] production Use `--omit=dev` instead.
2023-10-31T18:38:00.069Z [err] npm
2023-10-31T18:38:00.069Z [err] WARN deprecated [email protected]: Please consider using https://github.com/visjs
2023-10-31T18:38:01.788Z [err] npm
2023-10-31T18:38:01.788Z [err] ERR! code 1
2023-10-31T18:38:01.789Z [err] npm
2023-10-31T18:38:01.789Z [err] ERR! path /config/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
2023-10-31T18:38:01.796Z [err] npm
2023-10-31T18:38:01.796Z [err] ERR! command failed
2023-10-31T18:38:01.796Z [err] npm ERR!
2023-10-31T18:38:01.796Z [err] command sh -c node-gyp rebuild
2023-10-31T18:38:01.797Z [err] npm
2023-10-31T18:38:01.797Z [err] ERR! gyp info it worked if it ends with ok
2023-10-31T18:38:01.797Z [err] npm ERR! gyp info using [email protected]
2023-10-31T18:38:01.797Z [err] npm ERR! gyp info using [email protected] | linux | arm64
2023-10-31T18:38:01.797Z [err] ERR! gyp ERR! find Python
2023-10-31T18:38:01.797Z [err] gyp ERR! find Python checking Python explicitly set from command line or npm configuration
2023-10-31T18:38:01.798Z [err] npm ERR! gyp ERR! find Python - "--python=" or "npm config get python" is "/usr/bin/python3"
2023-10-31T18:38:01.798Z [err] ERR! gyp ERR! find Python - "/usr/bin/python3" is not in PATH or produced an error
2023-10-31T18:38:01.798Z [err] ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
2023-10-31T18:38:01.798Z [err] ERR! gyp ERR! find Python checking if "python3" can be used
2023-10-31T18:38:01.798Z [err] ERR! gyp ERR! find Python - "python3" is not in PATH or produced an error
2023-10-31T18:38:01.798Z [err] gyp ERR! find Python checking if "python" can be used
2023-10-31T18:38:01.798Z [err] npm ERR! gyp ERR! find Python - "python" is not in PATH or produced an error
2023-10-31T18:38:01.798Z [err] npm ERR! gyp ERR! find Python **********************************************************
2023-10-31T18:38:01.799Z [err] ERR! gyp ERR! find Python You need to install the latest version of Python.
2023-10-31T18:38:01.799Z [err] npm
2023-10-31T18:38:01.799Z [err] ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2023-10-31T18:38:01.799Z [err] ERR! gyp ERR! find Python you can try one of the following options:
2023-10-31T18:38:01.799Z [err] npm ERR!
2023-10-31T18:38:01.799Z [err] gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"
2023-10-31T18:38:01.799Z [err] gyp ERR! find Python (accepted by both node-gyp and npm)
2023-10-31T18:38:01.801Z [err] gyp ERR! find Python - Set the environment variable PYTHON
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! find Python npm config set python "/path/to/pythonexecutable"
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! find Python For more information consult the documentation at:
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! find Python **********************************************************
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! configure error
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack Error: Could not find any Python installation to use
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at PythonFinder.fail (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:330:47)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at PythonFinder.runChecks (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:159:21)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at PythonFinder.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:202:16)
2023-10-31T18:38:01.801Z [err] gyp ERR! stack at PythonFinder.execFileCallback (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:294:16)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at exithandler (node:child_process:430:5)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:290:12)
2023-10-31T18:38:01.801Z [err] gyp ERR! stack at onErrorNT (node:internal/child_process:477:16)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
2023-10-31T18:38:01.801Z [err] npm ERR! gyp ERR! System Linux 6.1.21-v8
2023-10-31T18:38:01.802Z [err] ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2023-10-31T18:38:01.802Z [err] npm ERR!
2023-10-31T18:38:01.802Z [err] gyp ERR! cwd /config/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
2023-10-31T18:38:01.802Z [err] gyp ERR! node -v v18.18.2
2023-10-31T18:38:01.802Z [err] npm ERR! gyp ERR! node-gyp -v v9.3.1
2023-10-31T18:38:01.802Z [err] npm ERR! gyp ERR! not ok
2023-10-31T18:38:01.811Z [err]
2023-10-31T18:38:01.811Z [err] npm
2023-10-31T18:38:01.811Z [err] ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-10-31T18_37_43_047Z-debug-0.log
2023-10-31T18:38:01.856Z rc=1
I tried to see if i could install python but i was unable to do this. i tried npm commands but i keep on getting this as response:
zsh: command not found: node
zsh: command not found: npm
does someone know how to solve this?
